Do I really need shocks with leveling kit? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-04-2011, 01:46 PM
Ian123's Avatar
Ian123 Ian123 is offline
Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.
I'm looking to buy a 2.5" leveling kit for my 07 f-250 diesel. I'm not looking for increased off-road performance I want it simply for looks. Do I really need to buy new shocks and castor shims? I can buy a level kit without all that stuff for 60 bucks whereas the 'complete' kits are a couple hundred and for that price hell I might as well go with a full on suspension lift. Once again, I'm not looking for the all-out, 100% correct, no corners cut way of leveling my truck. I just want it done as cheap as possible while still being safe and not giving me any problems driving down the road under normal driving conditions.
Old 05-04-2011, 01:51 PM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
yes you will, some companies give you cheap little spacers but id buy the longer better shocks anyways, OEM shocks suck and the aftermarket shocks will be so much better
Old 05-04-2011, 04:58 PM
Robs06SuperDuty's Avatar
Robs06SuperDuty Robs06SuperDuty is offline
Robs06SuperDuty is gaining momentum as a positive member of FTE.Robs06SuperDuty is gaining momentum as a positive member of FTE.
I didnt put longer shocks on mine when I did my F350 rear block swap & 2.5" Skyjacker coils up front, works fine how it is. Im running Bilstein HD's all around. Truck in Sig.
Old 05-04-2011, 08:41 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Unbolt the bottom of one of your front shocks and let it extend out. See how far down past the lower shock mount it extends. Will you still have some travel if you take 2 1/2" away from that excess distance? That will tell you if you need new shocks, but I'll agree. If you're still running factory shocks, it's worth changing them out even if you don't do the leveling kit.
The truck will need to be aligned after a leveling kit. You can either try and adjust it yourself or pay a shop to do it.
Old 05-06-2011, 12:50 AM
Ian123's Avatar
Well I decided to shop around for some shocks just for the hell of it. What lengths would I need for a truck with 2.5" leveling kit?
Old 05-06-2011, 01:07 AM
Bilstein - KYB - Rancho - Monroe - Edelbrock Automotive Truck Shocks and Struts - Shockwarehouse.com
they're a site sponsor.
You would need Stock Height or 0-2.5/3" of lift shocks.
Old 05-10-2011, 07:37 AM
scottzj's Avatar
scottzj scottzj is offline
Hangin 10 bra
scottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud ofscottzj has much to be proud of
Personally it depends on what shocks you have on the truck. My 04 King Ranch came factory with Ranchos and will still work perfectly with the leveling kit installed, so in my case i am good for now. I might change them out later on just to refresh to newer shocks.
Old 05-10-2011, 04:53 PM
ford 5.4 power's Avatar
ford 5.4 power ford 5.4 power is offline
ford 5.4 power is starting off with a positive reputation.
skyjacker 8000 are a very good cheep shock i have em an love them. skyjacker shocks go 0 to 4in lift befor you go to a dif shock size. ranchos are the same way good luck. my factory shocks would bottom out.
Old 05-10-2011, 05:39 PM
Quote:
thoses "Rancho's" are actually ford shocks painted white and slapped with a rancho sticker, beleive it or not lol
Old 05-10-2011, 06:58 PM
Ian123's Avatar
Well I did a search on another forum and found a guy who owns a suspension shop (I believe it was Truck Toyz Performance but don't quote me on that) and said that up to 2" of lift you can use the stock shocks, 3" and up need longer ones. Since I was looking at a 2.5" kit which is right in the middle rather than taking a chance I'll probably just go with a 2" leveling kit instead. I measured my fender wells and the rear is exactly 2 inches higher so that should work fine for me.
Now the bigger question that I've ran into is, do I need the adjustable track bar/track bar drop to center the axle? How far off will it be if I don't get one?
Old 05-10-2011, 07:08 PM
knuckleheadnut's Avatar
knuckleheadnut knuckleheadnut is offline
knuckleheadnut is starting off with a positive reputation.
with only a 2" lift on the front, the stock track bar will probably be OK. and most suspension shops will tell you anything up to 4" doesn't "need" a drop bracket. With just an add a leaf or two to get your 2", that's all you will probably need. I lifted mine a little over 3" in the front and the adjustable track bar came out to nearly exactly the same length eye to eye as the stock. install your lift and have the alignment checked. if it is too far out of spec on tracking, then just buy an adjustable and throw it on.
Old 05-10-2011, 07:13 PM
Ian123's Avatar
Ok cool. Thanks for the replies everyone
Old 05-10-2011, 07:49 PM
I had to git the trac - bar it made my ride so much smother the facktory bar put it in tomuch of a bind an made it go all over the road .i would try the facktory bar befor you git the aftermarkit bar good luck with that
Old 05-11-2011, 09:40 PM
scottzj's Avatar
Hangin 10 bra
Well Robby you are absolutely correct on the shocks! Those POS Ford dealers put rancho decals and boots on el cheapo shocks! What jerk wads haha.
Well on the 2004 models you do not need to get new shocks unless yours are blown. The shock mounts stay on the top part of the spring area so nothing changes distance wise there. You only need to change them if they no longer are working.
BEFORE
AFTER
Old 05-11-2011, 10:02 PM
yup, big thanks for Ford for that one haha. my stockers didnt last long at all, at 35K miles, when I put the Bilsteins on, I could compress the stockers with one hand and they wouldnt rebound. I have 84K on my truck now and still have the Bilsteins on... World of difference.
once again... lol
New shocks? BKM-WR3 1987 - 1996 F150 & Larger F-Series Trucks 4 02-13-2015 01:57 AM
Need advice on Shocks and Level Kit Tanman21 1999 to 2016 Super Duty 1 01-28-2014 05:37 PM
Leveling kit question 96eddiebf150 1987 - 1996 F150 & Larger F-Series Trucks 7 09-29-2011 09:20 PM
Leveling Kit? onuredneck707 6.0L Power Stroke Diesel 4 02-26-2011 11:06 AM
Lift vs Leveling Kit....a bit confused Sleepsafe 1999 to 2016 Super Duty 14 09-08-2009 11:55 PM
Tags
05, 15, duty, extend, f150, f350, factory, heavy, kit, kits, leveling, mounts, safe, shock, shocks, sit, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
