washed engine at car wash, now no alternator charge...
OK, so I had day off yesterday. Cleaned up truck and took it to car wash to blow engine off. After I noticed it cranking slower on every start. finally dead. I charged batteries and got it started, put a volmeter on batteries and dam, 12.05 V and no rise. restart it, dropped voltage to 11.97, no rise. Did I ruin alternator washing it?
I've been washing my engines with plenty of water for over 30 years and the only problem on older cars was that spark plugs would get wet and for few minutes I had misfire or dead cylinder before the heat dried it out.
On my cars/truck I don' t hesitate to spray alternator directly although I am trying to avoid electric wires. Electronics are well hidden in the boxes, so no worry about them.
If your alternator went bad because of some water - it had to have a problem before. Test the wire connection to it and if it is really bad, just replace it. New alternators run about $200 and they need new brushes every few years anyway.
You NEVER EVER wash the top of a Ford gas engine with coil over plug ignition unless you want tons of problems. A small amount of wd-40 on a rag will work wonders.
idi1993f350
05-15-2017 06:31 PM
PPrash
12-27-2016 01:12 PM
EXv10
12-07-2011 07:11 PM
pballernyc
09-25-2003 10:49 AM
