Reverse Alarm
can not use info center to turn it off you can only turn off the reverse aid but not the back up alarm also it is sooooo loud it can be heard even with windows up. I put in reverse with a upd driver next to me and he said it startled him and could not believe how loud it was......
The only way to turn off the back-up alarm is to physically unplug it. You will find the alarm mounted on the frame back by the spare tire. More info can be found in the following thread...
https://www.ford-trucks.com/forums/1...hime-help.html
There is actually quite a bit of truth to that... The unit is a very common one found on many commercial trucks out there. A 102 dB of "get out of my way"...
but, if you asked for it, why would you want to turn it off?!
I know.. cause you don't want it ALL the time..
San
Pretty funny! Actually, when I go to the dump to drop off my recycling, I turned it on to backup to the recycling drop off point. Love the look all of the other truck owners give me
Upfitter Switch
I'm looking for a way to ARM and DISARM the backup alarm using upfitter switches. There are times I want it "ON", such as busy parking lots, and times I want it "OFF". Like a campgound w/o trailer in tow.
If you have pictures, or install procedures.... PLEASE POST.. Maybe in a new Post...
all you need to do is run a power wire from a upfitter switch to the rear of the truck. Install a relay that when you put power to it, it will connect the reverse alarm to the stock wiring, thus turning on the relay. Or you could wire it so that when you flip the upfitter switch, it will shut off the alarm. Real simple.
