Fix oil pan leak how
Well it 87 f250 6.9L
PO punch hole with screwdrive though oil filter and end in oil pan
He patch with quiksteel it don't stop leak. It would drip everyday. 2-3 weeks I pour 1 gal oil for every 1000 miles.
Got tired of see oil stain so I remove and sand put metal screw in it. Patch with TONS of JB weld. Well it doesn't work. All it does make JB weld not harden it soft you could poke.
What can I patch with something that will work with oil and diesel? I don't think JB weld like oil or diesel they become soft goofy. Won't dry.
Nobody thinks anymore, talking about the PO, not you. What I would do it get some oil resistant RTV, some self tapping sheet metal screws, and a piece of thin sheet metal. Then drill some holes in the metal plate, put a bead of rtv around it and around the screw holes and fasten the plate over the hole with the screws. That should stop your leak, just make sure you get the right RTV and don't strip the screws.
I would weld it. If you don't have a welder or know someone who does, take it to a machine shop or muffler shop and they should be able to help you out for a small fee. That's the only permanent solution I can think of short of replacing the pan. I think any gasket maker will eventually leak.
on
The trick is to make sure the surface that you are JB welding is clean and DRY. You need to drain the oil so the level in the pan is below the hole. clean it with brake cleaner and sand all the paint and rust off of the area. JB weld takes forever to set up, so get the JB Quick. After you clean the area with brake cleaner and dry it off make sure the area around the hole doesnt get wet from oil seaping out. I have fixed a couple oil pans on power strokes this way, one a year ago and one 3-4 years ago. Both are still holding.
Resendiz
11-09-2016 11:03 PM
peka
08-26-2015 01:51 PM
