You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
1972 Chevy Custom 20 4wd $11,000
Truck was pulled in the class between stock and super stock(class has different name depending where you are: street legal, improved stock, hobby stock) Truck already has all safety items any club would require. Fuel tank, electric fuel pump, 6 al MSD and coil are the only things not on truck.
-3” body lift
-Dana 60 front with 4:11 Detroit Locker (1yr. old)
-Eaton rearend with military style differential
-Muncie 4-speed with profab straight cut 3rd gear
-Additional stock Muncie 4-speed will come with
-205 transfer case has broken case that is currently in truck (old style Profab straight cut gears)
-Additional stock 205 transfer case will come with
-Aluminum driveshaft loops
-Weight rack for front of truck
-12.75x33 B.F. Goodrich Mud Terrain tires
-Lexon in front window, Plexiglas in back window
-Real glass in doors
-Hand throttle is currently installed (old gas pedal is still installed)-
-2 disc McLeod clutch still at original shims
-Dash mounted switches and start button from JEGS
-Phantom gauges (tach, fuel pressure, water temp, oil pressure)
Engine(800 HP)
*515 cu., Mark IV 4-bolt main with GM crank and caps, block has been bore aligned and is internally balanced, sfi approved balancer
*Cast Iron Heads, Merlin VR race heads-Heads have been ported; titanium valves with a sportsman shaft mounted rockers; custom tall valve covers
*Edelbrock Victor Jr. intake with a Holley 850 HP carburetor with a spacer
*CSI electric water pump
*High rpm circle track power steering pump
*K&N air cleaner
*Barry Grant fuel regulator
*Over the frame headers to 4” bullet mufflers
I can put you in contact with the mechanic that has done the majority of the work on the engine the last time it was freshened.
Dick Cepek Tires and Rims $500
-35x17.5x15 Baja Cepek Tires, 1 new and other 3 have about 1/3
tread left
-Rims are also Cepeks(6 hole)
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
