Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-04-2011, 09:25 AM
motorjunkie motorjunkie is offline
Garage is empty, add now
motorjunkie is starting off with a positive reputation.
Help with rear u-joint conversion 63 econo
I have a USAF 63 econo that I am performing a drivetrain swap on. I have been told that it is a DANA 20. Of course the ujoints are TINY and this is my problem. I cannot find a conversion joint and am wondering if I have any options other than a rear end swap. Is there a yoke swap I could perform?
the ujoint specs I would need are below.
2.5625" = 650.875mm spread
1" = 25.4mm cup
3.25" = 825.5mm spread
1 1/16 (1.0625") = 26.9875mm cup
  #2 (permalink)
Old 05-04-2011, 04:25 PM
smalltrucker's Avatar
smalltrucker smalltrucker is offline
smalltrucker is starting off with a positive reputation.
Might want to contact someone like Denny's driveshaft, got lots of odd ball stuff. Depending on what you are going to be putting out for power, might be a good idea to swap rears. Just some thoughts.
Dave
  #3 (permalink)
Old 05-10-2011, 10:13 PM
dmanlyr dmanlyr is offline
dmanlyr has a very good reputation on FTE.dmanlyr has a very good reputation on FTE.dmanlyr has a very good reputation on FTE.
I have to agree, part of the drivve train is the rear axle and if you have increased your power, it may not hold up well.
David
__________________
90 F250 7.5L E4OD, 99 F250 SD 7.3L E4OD for work, 88 E150 5.8 C6, 70 C600 dump truck - yes, even this is a AUTOMATIC! O2 Oldsmobile Bravada, Kubota L3200, Hustler Super Z mower, Sears mower, all Hydrostatics, 85 Honda Elite 150 scooter CVT - Nary a manual in the fleet!
Tags
150, 2004, 2008, conversion, escape, ford, i6, joint, joints, rear, swap, truck, universal, v8, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
