Plug-N-Play Bi-Directional Remote Start w/ Vehicle Security
Old 05-04-2011, 12:16 AM
PowerStrokeHD's Avatar
PowerStrokeHD
PowerStrokeHD is offline
Arrow Plug-N-Play Bi-Directional Remote Start w/ Vehicle Security
Just wanted to let those who may be interested know that Ford Accessories is will be offering a Series 200 Plug-N-Play Bi-Directional Remote Start w/ Vehicle Security for the 2011 Super Duty. This is the same as the Series 100 Plug-N-Play Bi-Directional Remote Start that a few members have already installed with the addition of vehicle security/alarm functionality.
The part number is BB5Z-19G364-C with a SRP of $298.57
Kit Contents:
[1] Bi-Directional Key Fob
[1] Antenna Jumper Wire (Not used if you have factory remote start as it is already installed.)
[1] Antenna Module (Not used if you have factory remote start as it is already installed.)
[1] Remote Start Module
[1] Bi-Directional Antenna
[1] TPM Module T-Harness
[1] Shock Sensor
[1] LED
Old 05-04-2011, 06:02 AM
lexustbs's Avatar
lexustbs
lexustbs is offline
Does this one beep when you start it? Is the install too hard?
Old 05-04-2011, 06:23 AM
Marauder92V's Avatar
Marauder92V
Marauder92V is offline
PowerStrokeHD - I'm confused. With the series 100 kit I installed, is my alarm turned off while in extended remote start? What does this kit give me exactly? More importantly, what components would I need to buy to make my 100 a 200 series. Thanks for letting us know about it!
Old 05-04-2011, 01:57 PM
PowerStrokeHD
Functionality of the existing security features are not affected by the installation of either the 100 or 200 systems. Everything works together as a happy family...
What the 200 system adds over the 100 is the security/alarm features. This would be the addition of the shock sensor, a additional indicator LED and a alarm (uses the horn) that would actually sound if say someone decides to break into your truck using the most common screw driver under the door handle trick.
Unfortunately at this time I am not seeing anyway to upgrade your 100 to a 200. This is all new though and the info is just starting to trickle out...
Old 05-04-2011, 04:00 PM
Part-Timer's Avatar
Part-Timer
Part-Timer is offline
If it provides additonal security features along with a longer range remote start over the standard remote start that comes with the truck then I'd be interested. Any idea where I can order one? I've checked the usual online parts vendors, but have had no luck in finding anything with that listed part number. The Ford accessories website doesn't list the series 200 unit yet either.
Brian
Old 05-05-2011, 07:52 PM
kdubinwa's Avatar
kdubinwa
kdubinwa is online now
Originally Posted by PowerStrokeHD
Just wanted to let those who may be interested know that Ford Accessories is now offering a Series 200 Plug-N-Play Bi-Directional Remote Start w/ Vehicle Security for the 2011 Super Duty. This is the same as the Series 100 Plug-N-Play Bi-Directional Remote Start that a few members have already installed with the addition of vehicle security/alarm functionality.
Kit Contents:
[1] Shock Sensor
[1] LED
No sign of that part number or any Series 200 remote at the Ford Accessories Online Store!?
Where can I learn more?
Thanks
Old 05-05-2011, 08:59 PM
Marauder92V
Check with the Ford guy who checks in here (PartsGuyEd). I bought the original series 100 extended remote kit from him. I am looking through the part listing for the series 200 to see if I can buy just the components to make my 100 into a 200. I like the idea of a shock sensor and the LED. From what I can tell thus far, I will need the shock sensor, the LED kit and the controil module. I already have the extended range antennae, the factory remote antennae and the small parts.
Old 05-05-2011, 10:04 PM
PowerStrokeHD
Thanks
Easiest would be to contact a Ford parts department to see if it is even in the system yet for ordering...
Old 05-06-2011, 04:59 PM
Part-Timer's Avatar
Part-Timer
Just heard back from Partsguyed. He doesn't have this unit in stock, and he didn't mention whether or not it was in the catalog either. He did mention that the series 100 units were on special.
Old 05-06-2011, 05:05 PM
kdubinwa's Avatar
kdubinwa
It isn't a valid part number based on a call to my local dealer. Where did you get this information PowerStrokeHD?
Old 05-08-2011, 08:33 AM
lexustbs's Avatar
lexustbs
lexustbs is offline
Let me know what you come up with on the parts.... Im not going to pay $300 for the same parts.
Old 05-08-2011, 10:22 AM
Marauder92V
Will do. Waiting for it to show up in the system to see if I can order just the "upgraded" components.
Did you ever get yours to work?
Old 05-08-2011, 10:27 AM
Marauder92V
I'm not surprised he has the 100 series on sale. With the added capabilities of the 200 series who will want them? PowerStrokeHD has always been extremely accurate on his information. Either the dealers haven't kept updated or they are pushing the 100 series to move stock.
Old 07-04-2011, 12:31 PM
uscgmkcret03's Avatar
uscgmkcret03
uscgmkcret03 is offline
What is the range and how long do they run on the Ford remote starts, 100 vs 200. @-50need the ole girl to warm up a while.
Thx
Old 07-04-2011, 05:13 PM
marchare011's Avatar
marchare011
marchare011 is offline
I have the factory remote start unit on my truck. On a normal day, it will reach 150-200 feet. I have never tested the range to see how far away it will work. I'm just saying normal everyday Walmart parking lot, baseball game parking lot, type of use. You can adjust the length of run time in 5 minute increments up to 15 minutes. I use the 15 in the winter and 10 in the summer.
Quick Reply: Plug-N-Play Bi-Directional Remote Start w/ Vehicle Security
