Have to Push Hard on Brakes to Stop
on
Like said above, check and lube slide pins first, and that will give u a feel also for what pad condition is while in there.
I had this issue last fall. I'm 260 lbs and I had to grab bottom of wheel and step into pedal with both feet while pushing back into the seat and I could not get the abs or tires to lock on wet roads. I knew slide pins and calipers where good cuz I maintained 2 times a yr. I ended up changing front rotors and shoes to the cryogenic power slot with hawk pads to get my braking to where it should be.
I feel u will have a brake job in your near future.
freeriders98
10-27-2016 10:09 PM
frogjaw
1999 to 2016 Super Duty
07-12-2016 10:41 AM
