Trans issue to rest! Maybe?
So I finally got my trans rebuilt and it seems at the moment to work great. I still have a leak issue in 2 spots but I think that is minor compared to the small flood from before is was rebuilt. Here is the one question that I have. the C-6 on my 302 needs to pull vacuum and I dont think that the spot it is pulling from is correct. The shop that I got the trans rebuilt from said to have the vacuum pull from the spacer or spacers that are between the intake manifold and the carb. I dont have is connection and the previuos owner was running a "T" connector from the carb to the distributor and the trans was at the "T". I feel that this is bad and the shop even stated not to have it connected to a "T" fitting. I do have a connection at the back of the intake manifold by the firewall and I think this would be better suitted but then I'm afraid of having to much vacuum. Please any thoughts or suggestions would be great!
Thanks.
Just tell the parts guy you're looking for a ported carb spacer.You'll need to know what carb and intake you have,as they are brand specific.If you'd like to get an idea of what they look like,go on Summit Racing or Jeggs sites.Here's one from Ebay:
1" Aluminum Carb Spacer Carburetor Pro Series Port | eBay
Notice it is of the open plenum style,that is one large open hole.Closed plenum ones would have multiple holes corresponding to the number of venturi the carb has.Search for carb spacer on the Bay to get ideas.
So I have been looking the plates up and have only come up with ones that have an EGR port on them and I dont have that on this motor. Can I assume that this is an aftermarket or custom plate that I'm searching for. Does this plate have a specific name? I guess if at all possible it would be nice not to have to sink more money into this to get a little vacuum.
Thanks.
Thanks.
I'm not the sharpest tack in the drawer, but I'd say yes,you would get a stronger vacuum signal there,as opposed to taking it from the carburetor.
For the transmission, you want full manifold vacuum. You can't or won't have too much. The port on the back of your intake manifold is where it would have come from originally. But not the EGR valve, and definitely not from a port on the carb. In this photo, there's a vacuum "tree" at the back of the intake. That's what/where you want to come from.
@buzzard! You still did help alot with just replying!
