how does the adjustable vacuum advance work?
I was hoping sleepy or someone i've talked to in the past few weeks about timing could help me on this. I bought an adjustable vacuum advance for my duraspark distributor and installed it today. My question is how do you set it and what are you doing when you turn it with the allen wrench, because when I turned it nothing moved unless nothing is supposed to move that you can see?
I was not gonna be able to run 16 initial with the stock vacuum advance, so I was told to get this so I could and back off the vacuum.
I'd like some responses asap because i'm goin back over to work on the truck again and get everything set right.
Here's everything you need to know... FORDMUSCLE webmagazine: Timing is Everything - Distributor Curving for Maximum Power
Every application is unique e.g. tow rig, hi-po street truck, etc. but you can experiment with different spring rates to find your sweet spot, these are big heavy trucks, so generally speaking, full advance before 2,500 rpm is a bit too soon, i'd recommend having your advance "all in" somewhere around 3,000-3,500 rpm, it takes a little trial and error to dial it in correctly.
lvin4jc
27
01-02-2017 05:10 PM
Ford59galaxie
21
02-12-2016 05:29 PM
ULpilot
07-13-2015 10:48 AM
NW 150
18
04-03-2012 08:05 PM
