"91" F150 4x4 - Ford Truck Enthusiasts Forums
"91" F150 4x4
Old 05-03-2011, 05:54 PM
Preemo Preemo is offline
Preemo is starting off with a positive reputation.
"91" F150 4x4
can anyone tell me how to identify my tranny,
Old 05-04-2011, 09:05 AM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
Auto or manual?
Old 05-04-2011, 09:25 AM
vochy vochy is offline
vochy is starting off with a positive reputation.
If it is original the code in the door jam will tell you. Otherwise you will have to give us more info. Auto/manual, OD? If it is an auto, the there are prety much 3 options. Most likely an AOD, EAOD, or C6. I don't think it would be a C4. If no OD then it is a C6. If it has push button OD then it would be an EAOD. If it has OD and no way to keep it in 2 and the the selector reads PRN(D)D1 then it is likely an AOD. Some guys on here can also tell you by the bolt pattern on the pan. Hope this helps!
Old 05-04-2011, 12:18 PM
jas88's Avatar
E4OD, not EAOD.
Old 05-04-2011, 12:33 PM
Correct, E4OD
Old 05-04-2011, 05:01 PM
tranny is auto with push button on/off OD
Old 05-04-2011, 06:39 PM
CWPottenger CWPottenger is offline
CWPottenger is gaining momentum as a positive member of FTE.
Should be an E4OD then
Old 05-04-2011, 06:48 PM
ok thanks, got to replace flex plate, dont know if it matters what tranny, but its behind a 302
Old 05-05-2011, 07:26 AM
I don't know how much those cost new but you might be able to find 1 at a junk yard for next to nothing. What did you do to it that you need to replace your flex plate?
Old 05-05-2011, 09:10 PM
replaced engine, rebolted tranny without lining up converter with flex plate, figured it poped it, making a kinda clicking sound
Old 05-07-2011, 11:49 PM
bought a new one for 50 bucks, gonna replace tomorrow
Thanks for the info guys
Tags
1991, 4x4, 91, f150, ford, show, specs, supercab, tuner, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
