How can I tell how much lift is on the truck i just bought?
05-03-2011, 05:46 PM
on
It is a 2005 f 250
05-03-2011, 06:09 PM
on
depends. most kits come with new front springs and shocks. compair old spring to new one. also rear block measurement. the back is normally 1-2" shorter so say the block is 4" then the lift will be a 6" lift
05-03-2011, 08:29 PM
on
Measure from the bottom center of fender to center of front hub on a known stock truck and than measure yours.
05-03-2011, 09:41 PM
on
Post a pic and I can proabably tell you just by looking
05-04-2011, 05:08 PM
Measure the front, because there is more consistency in lifts on the front. Rears vary by too many factors.
Measure from the ground to the apex of the wheel well arch. Or the center of the wheel if you prefer.
My stock height truck measures around 40" from the ground to the apex of the wheel well arch, with 33" tires.
What is yours?
05-04-2011, 07:37 PM
on
05-04-2011, 07:52 PM
on
That would be a 6 inch lift most likely
05-05-2011, 09:09 AM
Sounds about right to me.
2002exPSD
05-18-2017 11:34 PM
nuknuk
08-22-2016 04:55 PM
FlthyRufneck
Utah Chapter
03-26-2015 01:42 PM
2002exPSD
1983 - 2012 Ranger & B-Series
08-10-2011 01:17 PM
tfdhanna
1997 - 2003 F150
01-27-2004 02:06 PM
03 ,
46s ,
clear ,
diesel ,
f150 ,
f250 ,
ford ,
lift ,
lifts ,
ma ,
measure ,
put ,
rancho ,
truck ,
trucks
