Phasers or VCT solenoid?? - Ford Truck Enthusiasts Forums
Old 05-03-2011, 02:09 PM
shepshu shepshu is offline
shepshu is starting off with a positive reputation.
I have 07 sscrew with 5.4. 93,000 miles. At start up truck runs perfect. After 20-30 minutes of running motor will start to start running rough at low rpm. Diesel sound. I can rev up and motor clears up and idles fine. Should I replace VCT solenoids? Or phasers? Or both at one time?? Help its driving me nuts!!
Old 05-03-2011, 02:41 PM
MCDavis's Avatar
MCDavis MCDavis is online now
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
If you're thinking that's what it is...which is likely, then I'd start with the least expensive part first. VCT solenoids.
Old 05-03-2011, 03:02 PM
I think the same way. However, to replace VCT solenoids on an 07 you have to remove valve covers anyway. So I figured do both. I just drove it on a short errand and it sounds like a new truck. Runs perfect. Only after heating up is when it will idle bad like a diesel. Rev it up and it goes away. All good maintenance.
Old 05-03-2011, 03:03 PM
Very frustrating.
Old 05-03-2011, 03:18 PM
MCDavis's Avatar
Thinking on this more, I'm curious if a vacuum leak could attribute to this. Leaking might not form until the hose warms up and expands slightly.
Just an idea...thinking out loud here.
Old 05-03-2011, 03:24 PM
I checked all lines I could. I was thinking same thing. From what I've read on other posts it sounds like classic phaser issue, but it doesn't do it until it reaches a certain temp. I pulled oil pan and wasn't all that bad. Had engine flushed out and new oil and filter.. I know solenoids have screens in them where oil passes through. Maybe one has some debri on it. I'm probably gonna replace vct and phasers just to be safe..
Old 05-03-2011, 03:25 PM
Oh yea and no codes are showing up...
Old 05-03-2011, 08:10 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is online now
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
Check the crankshaft endplay. They had problems with the thrust bearings in 2007 wearing out causing the crank to walk and lose oil pressure. Was there any metal in the pan when you had it off? Oil pressure at hot idle should be minimum 25psi.
Old 05-03-2011, 11:15 PM
Shawns Fords's Avatar
Shawns Fords Shawns Fords is offline
Shawns Fords is starting off with a positive reputation.
To test for VCT noise:
  1. Place the transmission in park or neutral
  2. Bring engine oil temperature to 160 F (71 C) or above as indicated by the scan tool "EOT" PID.
  3. Allow engine to idle, and determine if noise is noticeable.
  4. Set engine speed to over 1200 RPM (if noise is a VCT knock, the noise should disappear).
  5. Return engine speed to idle (verify knock returns).
If the noise intensity is more than a lightly audible knock at hot idle under 1200 RPM at engine operating temperature, replace the cam phaser
Hope that helps you figure it out
Old 05-04-2011, 02:09 AM
mtnlovrs's Avatar
mtnlovrs mtnlovrs is offline
mtnlovrs is starting off with a positive reputation.
Usually, the diesel noise happens for the first 2-3 seconds after start-up, then goes away. As the phasers get worse, it does as you described. Eventually, it causes the timing chains to beat the heck out of the guides, then they fall apart and clog up your oil pick-up tube. And finally, your engine self destructs! This is what happened to my truck - except for the self destruct part. The solenoids never did get replaced and are still fine and it runs good now ($2600 later). It sounds like phasers, both timing chains, gears, tensioners, guides and oil pick-up tube to me. That was my fix and Ford did all the work. Good luck.
Old 12-06-2011, 10:14 PM
RAM7880 RAM7880 is offline
RAM7880 is starting off with a positive reputation.
what was the outcome,solinoid or phasers?
Old 12-07-2011, 03:06 PM
ChrisCarter ChrisCarter is offline
ChrisCarter is starting off with a positive reputation.
You do not have to remove the valve covers to replace VCT Solenoids on any 5.4L 3V! If it runs fine at start up then warms up then it could be a lot of stuff, but I am leaning towards vct solenoid. Unplug and see if it runs better!
Old 12-08-2011, 10:12 PM
NHRA3637 NHRA3637 is offline
NHRA3637 is starting off with a positive reputation.
i have the same problem. i changed solenoids, phasers. and timing chain tensioners. 600-1000 rpm hear a tick noise then let off runs rough. give a little gas and clears up...totally confused. i unplug solenoid it runs fine
Old 12-16-2011, 10:19 PM
is unpluging the vct solenoids an accurate test? or does it only work for a specific problem with the solenoid
Old 12-17-2011, 09:48 AM
i think it's an oil leakage problem in the right cyl head. i removed both valve covers and checked for oil flow to both front cam caps. i have good flow and pressure through caps to phasers. i do notice rt cam caps bleeds more than left cam cap. not sure it's a cylinder head issue or a cam issue. by disconnecting the solenoid it keeps the oil constant to cam shaft. when solenoid is energized it changes the flow to advance or retard timing. so by disconnecting just one solenoid in goes in open loop. the truck runs fine and has power. just causes the check engine light to come on and vct won't adjust timing to control egr function. so until i have a some idea how to fix i'll just run it this way until it blows up.
2005 5.4 starting, sounds like diesel Garden Spyder Modular V8 (4.6L, 5.4L) 9 01-23-2017 01:24 PM
Phaser Tick Fix without replacing Phasers. ChrisCarter 2004 - 2008 F150 71 12-07-2016 12:15 PM
Vct electrical issues Mikesqm900 2004 - 2008 F150 3 10-18-2016 07:09 PM
07 EB - "lumpy" idle after phaser lockout install uncleben03 2007 - 2014 Expedition & Navigator 5 01-13-2016 07:09 PM
Questions about VCT System - P0012 and P0021 Codes jtillery 1997-2006 Expedition & Navigator 6 02-15-2014 01:49 PM
Tags
2004, 2005, 54, changing, f150, ford, number, part, phasers, replacement, runs, solenoid, truck, unplugged, vct
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
