Vacuum line schematic for 2001 5.4 Triton engine - Ford Truck Enthusiasts Forums
Old 05-03-2011, 02:45 PM
John Scruggs John Scruggs is offline
John Scruggs is starting off with a positive reputation.
Could someone please provide me with a detailed schematic for a 2001 F250 4x4 vacuum line system?
Old 05-03-2011, 04:39 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
BURNSTOUGHFORD has a good reputation on FTE.BURNSTOUGHFORD has a good reputation on FTE.
Should be under your hood near the hood latch.
Old 05-03-2011, 06:10 PM
Vacuum schematic
Thank you. It should be there, but it isn't. I have one 3/8" vacuum tube sticking out of the throttle body and can't find the line that hooks up to it or figure out where it goes or what it does. For now, I plugged the line with a piece of hose and a bolt until I find out. I have a check engine light, but the engine runs well. I compared it to an older Expidition and that approach didn't solve my problem. A good schematic would certainly help. A friend hoped I could solve the problem for him after he switched engines.
Old 05-08-2011, 12:12 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
I am trying to remember what it went to if anything on the 01 I had. What codes are you getting causing your CEL?
Is this the one that you are referring to?
http://www.ford-trucks.com/user_gall...=99254&width=2
Old 05-09-2011, 01:18 PM
Vacuum lines
My firend hasn't taken his truck to a parts store where they will run obd 2 codes for free, but it is a great idea. Perhaps doing so will give him an indication what isn't hooked up. We can probably also get a schematic from the Ford garage. He is very busy with college, two jobs, two kids, and the Oregon National Guard. I'll pass your tip on to him this afternoon. If nothing else we'll find an '01 on a used lot somewhere and look. Thanks for your ideas. J.S.
Old 05-10-2011, 09:14 PM
LxMan1's Avatar
Did you look at the picture I linked ?
Old 05-12-2011, 12:54 PM
I have not been able to locate any photo link. Thanks for trying.
Old 11-06-2012, 10:37 AM
dimondale414 dimondale414 is offline
dimondale414 is starting off with a positive reputation.
Do u have a pict of the other side of the pict u sent the drivers side of the motor
Old 11-23-2013, 11:41 AM
kdwellssr's Avatar
kdwellssr kdwellssr is offline
kdwellssr is starting off with a positive reputation.
I know this is a old post but if anyone is watching it.... Any way to see where the vacuum lines go that are closer to the side of the battery where the small chamber is and the lines go off it to somewhere.?
Old 03-07-2014, 02:21 PM
rocknrod rocknrod is offline
rocknrod is starting off with a positive reputation.
So the answer is no diagram?
Old 03-10-2014, 05:09 AM
frankyd frankyd is offline
frankyd is starting off with a positive reputation.
seen your post
If you are talking about the vacume lines that go behind the battery near the fender then yes. One goes to the plastic thing (I dont know what its called) and the other is a vent hose that goes to the front differential to vent it (dont know why ford did that eather but they did) I know that because I just removed my battery and the plastic tray that it sits on today while looking for a vacume leak
Hope this helps you out
Quote:
Old 03-10-2014, 05:13 AM
seen your post
I dont have a diagram but what were you looking to find on the diagram if someone had one?
Quote:
Old 03-10-2014, 06:50 AM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
off the throttle body is a large plug with 3 small lines coming out of it.
one goes to the fuel pressure regulator on top of the passenger side valve cover,
one goes to the passenger side vacuum accumulator for the heater controls,
and the third goes to the driver side, i believe to the EGR.
there are only 3 lines off that intake port.
the line off the vacuum accumulator goes inside the cab to a 2 way splitter. one line goes to the blend door, the other goes to the heat/ac control switch.
it is a very simple system.
99 F250 5.4 vac schematic largetonnage 1999 to 2016 Super Duty 2 05-26-2015 10:05 AM
Vacuum / EGR schematic Big Rhino Ford Inline Six, 200, 250, 4.9L / 300 1 01-30-2015 05:46 PM
Ford V10 Vacuum line schematic Irelands child 1999 to 2016 Super Duty 2 12-02-2010 08:51 PM
Anyone Have a Vacuum Schematic for a 98 5.4? Fox Fader 1997 - 2003 F150 4 10-17-2010 09:34 PM
1978 F150 Vacuum Diagram gillman.6 New Member Introductions 4 08-03-2009 09:07 AM
Tags
2001, 2004, 54, 98, diagram, expedition, f250, ford, hose, line, lines, liter, specs, triton, vaccum, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
