2000 F150 Shift Linkage Cable - Ford Truck Enthusiasts Forums
Old 05-03-2011, 02:16 PM
fordhacker150 fordhacker150 is offline
fordhacker150 is starting off with a positive reputation.
I've got a 2000 F150 5.4L 4x4. The shift linkage is real loose, I can't get it into park without rolling it in (bad on the tranny I know). My question is, how much, if any, can the shift linkage cable be tightened, or would a replacement be easier..
Thanks for the advice fellas.
Transmission linkage photos Thomas Hutchins 1997 - 2003 F150 0 08-23-2014 12:53 PM
Pic Request: 92-96 C6 shifter linkage at trans custom1106 1987 - 1996 F150 & Larger F-Series Trucks 3 03-30-2014 03:33 AM
Shift Linkage Adjustment 93Sunplex Clutch, Transmission, Differential, Axle & Transfer Case 0 02-27-2007 07:58 AM
diagram of tranny shift linkage 95Ford4x4 Clutch, Transmission, Differential, Axle & Transfer Case 0 02-21-2007 03:15 PM
steering column repair h-m Brakes, Steering, Suspension, Tires, & Wheels 4 12-01-2006 02:02 PM
Tags
1997, 2000, 2004, cable, f150, f150shift, ford, linkage, navigator, ranger, shift, shifter, shifting, tighten, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
