How to Tell When Harmonic Balancer Might Be Going Bad?
Old 05-03-2011, 01:12 PM
cigarxtc's Avatar
cigarxtc
cigarxtc is offline
Question How to Tell When Harmonic Balancer Might Be Going Bad?
I was wondering how to tell when a harmonic balancer is going bad? There is an odd metalic clanging that i can not isolate. It's been happening the last month. It seems almost sporadic, but i can feel and hear it more at 1100rpm in 2nd gear. Though it may appear at other speeds and gears. I've visually inspected everything under the front end and near the trans and engine mounts. I grabbed and tried shaking every moving part under the cab and front suspension but could not find any loose ball joints, nuts/bolts, etc...... I even opened the trans flex plate inspection hole and could not feel any give or free play in the plate to torque converter. I'm perplexed. The truck tracks straight and brakes fine.
Old 05-03-2011, 01:16 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
The harmonic balancer inner and outer are separated by a rubber layer.
Best to see what the condition is just look for dry cracks in the rubber or install a stop in #1 spark plug and verify the balancer still shows true TDC
Josh
Old 05-03-2011, 03:48 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
The harmonic balancer is made up from three parts: Outer pulley, inner damper and a rubber gasket.
At the factory, the gasket is placed between the pulley and damper, then the pulley/gasket/damper is pressed together forming a one piece assembly.
When the gasket age cracks, shrinks, this causes the outer pulley to "walk away" from the inner damper.
If not caught in time, the parts will separate, the pulley may strike the radiator core, taking associated parts along with it. Not pleasant.
Old 05-03-2011, 03:54 PM
Sleepy445FE's Avatar
Sleepy445FE
Sleepy445FE is offline
I've had one explode on a Olds Cutlass just sitting in a drive through. I'm lucky it was front wheel drive and it just hit the inner fender. Made a nice little dent. Could've been bad if there had been a radiator in front of it. I found out later that there was a recall on those balancers...
Moral of the story, don't wait until it "seperates" to replace.
Old 05-05-2011, 11:59 AM
cigarxtc's Avatar
cigarxtc
cigarxtc is offline
Here's a pic of my balancer. I am not sure how long that rubber has been peaking out, but that is bad, right?
I'm thinking of ordering a replacement from Summit, but have no clue what to get. I put my engine details(stock 351modified) in their search and i see four options:
PIO-DA-3512-HD
ATI-918930
PIO-DA3512
FLU-620200
Three are rubber dampers, one is liquid. The ATI one says it needs seperate hub. What is that? What do ya'll recommend?
Old 05-05-2011, 12:33 PM
NumberDummy
ACH! Time to replace, the outer pulley is "walking away" from the inner damper.
Only a fraction of the very edge of the gasket can be seen when the balancer is OK.
Dunno what balancer you need since you haven't mentioned what size the engine is.
Old 05-05-2011, 12:39 PM
cigarxtc's Avatar
cigarxtc
cigarxtc is offline
doh. i forgot to add the engine info. it's in the post above now. 351m stock.
Old 05-06-2011, 04:41 PM
cigarxtc's Avatar
cigarxtc
cigarxtc is offline
Another question, do i need to install a new bolt or reuse the old bolt for the new harmonic balancer?
CreeperVan
64
08-17-2018 08:51 PM
Chipper45
1999 to 2016 Super Duty
18
04-17-2017 08:37 PM
myakkacracka
13
06-16-2016 11:33 AM
majestek12
09-16-2015 02:06 PM
RANGER589
18
06-03-2011 10:03 AM
Quick Reply: How to Tell When Harmonic Balancer Might Be Going Bad?
