How to Tell When Harmonic Balancer Might Be Going Bad? - Ford Truck Enthusiasts Forums
Old 05-03-2011, 01:12 PM
cigarxtc's Avatar
cigarxtc cigarxtc is offline
cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.
Question How to Tell When Harmonic Balancer Might Be Going Bad?
I was wondering how to tell when a harmonic balancer is going bad? There is an odd metalic clanging that i can not isolate. It's been happening the last month. It seems almost sporadic, but i can feel and hear it more at 1100rpm in 2nd gear. Though it may appear at other speeds and gears. I've visually inspected everything under the front end and near the trans and engine mounts. I grabbed and tried shaking every moving part under the cab and front suspension but could not find any loose ball joints, nuts/bolts, etc...... I even opened the trans flex plate inspection hole and could not feel any give or free play in the plate to torque converter. I'm perplexed. The truck tracks straight and brakes fine.
Old 05-03-2011, 01:16 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
The harmonic balancer inner and outer are separated by a rubber layer.
Best to see what the condition is just look for dry cracks in the rubber or install a stop in #1 spark plug and verify the balancer still shows true TDC
Josh
Old 05-03-2011, 03:48 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
The harmonic balancer is made up from three parts: Outer pulley, inner damper and a rubber gasket.
At the factory, the gasket is placed between the pulley and damper, then the pulley/gasket/damper is pressed together forming a one piece assembly.
When the gasket age cracks, shrinks, this causes the outer pulley to "walk away" from the inner damper.
If not caught in time, the parts will separate, the pulley may strike the radiator core, taking associated parts along with it. Not pleasant.
Old 05-03-2011, 03:54 PM
Sleepy445FE's Avatar
Sleepy445FE Sleepy445FE is online now
Sleepy445FE is gaining momentum as a positive member of FTE.Sleepy445FE is gaining momentum as a positive member of FTE.
Quote:
I've had one explode on a Olds Cutlass just sitting in a drive through. I'm lucky it was front wheel drive and it just hit the inner fender. Made a nice little dent. Could've been bad if there had been a radiator in front of it. I found out later that there was a recall on those balancers...
Moral of the story, don't wait until it "seperates" to replace.
Old 05-05-2011, 11:59 AM
cigarxtc's Avatar
Here's a pic of my balancer. I am not sure how long that rubber has been peaking out, but that is bad, right?
I'm thinking of ordering a replacement from Summit, but have no clue what to get. I put my engine details(stock 351modified) in their search and i see four options:
PIO-DA-3512-HD
ATI-918930
PIO-DA3512
FLU-620200
Three are rubber dampers, one is liquid. The ATI one says it needs seperate hub. What is that? What do ya'll recommend?
Old 05-05-2011, 12:33 PM
ACH! Time to replace, the outer pulley is "walking away" from the inner damper.
Only a fraction of the very edge of the gasket can be seen when the balancer is OK.
Dunno what balancer you need since you haven't mentioned what size the engine is.
Old 05-05-2011, 12:39 PM
cigarxtc's Avatar
doh. i forgot to add the engine info. it's in the post above now. 351m stock.
Old 05-06-2011, 04:41 PM
cigarxtc's Avatar
Another question, do i need to install a new bolt or reuse the old bolt for the new harmonic balancer?
HELP! New motor... Harmonic vibration. CreeperVan Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 12 02-13-2017 02:15 PM
2003 Excursion - Vibration (lengthy) majestek12 Excursion - King of SUVs 27 09-16-2015 02:06 PM
Mods, Maintenance, and Life(long and kind of pic heavy) redman84 1994.5 - 1997 7.3L Power Stroke Diesel 17 05-29-2013 12:38 PM
Camshaft???? RANGER589 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 18 06-03-2011 10:03 AM
Bad Harmonic Balancer FSJ-EARL 1999 - 2003 7.3L Power Stroke Diesel 7 07-20-2010 10:58 AM
Tags
150, 1987, 38, 78, bad, balancer, caravans, econoline, f150, ford, harmonic, install, motor, mount, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
