Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
  #1 (permalink)
Old 05-03-2011, 10:46 AM
JoeKan JoeKan is offline
Garage is empty, add now
JoeKan is starting off with a positive reputation.
how many quarts of oil?
Hello,
I'm going to check the pricing on oil to see if I can save any by changing it myself. I have an 00 X with 7.63. I've always taken it to the dealer to have the oil chaned, cost around $60-$70. I don't remember. Can someone tell me how many quarts this motor holds? I seem to remember that it's around 12. Thanks for the input,
Joe
  #2 (permalink)
Old 05-03-2011, 11:02 AM
tims01's Avatar
tims01 tims01 is offline
tims01 has a good reputation on FTE.tims01 has a good reputation on FTE.tims01 has a good reputation on FTE.
17 quarts .... . and i have already priced it and its cheaper to have jiffy lube do the oil changes
  #3 (permalink)
Old 05-03-2011, 02:24 PM
airjeff airjeff is offline
2005 Ford Excursion
airjeff is gaining momentum as a positive member of FTE.airjeff is gaining momentum as a positive member of FTE.
Something to consider...
Jiffy lube does not care about your truck. They want to make as much money as possible. As such, they will use the cheapest filter and oil they can find. Do some searching on 6.0 oil filters and you will find using anything but the good stuff is a bad idea. You can argue oil is oil, but I like putting quality oil in the engine...very cheap insurance. Usually it is hard to beat oil shop prices, but you'll be using better products doing it yourself.
Watch for stuff to go on sale and you can get pretty good prices. I got Mobil1 for $20/gal and the good filters online for about $14 I think. So say $94ish for a synthetic oil change.
__________________
2005 Excursion EB 6.0L 4x4, 3.73, BPD EGR, V/B,\\ F350 sway, Firstone bags, IDP X3, Diesel Site Coolant Filter, SEIC, XD Revolvers, Nokian Vativa A/T 275/70/18
2006 MazdaSpeed6 GT, some stuff done to it
  #4 (permalink)
Old 05-03-2011, 02:39 PM
baracade's Avatar
baracade baracade is offline
1966 Ford F-100
baracade is starting off with a positive reputation.
My 03 7.3 took 14 quarts with filter change. Use the best oil and filter you can!
__________________
1966 F 100 CC
2007 F 150 5.4
2003 Excursion 7.3L (gone but not forgotten)
2010 MKX (wife's ride)
  #5 (permalink)
Old 05-03-2011, 05:52 PM
tdappleman tdappleman is online now
tdappleman has a great reputation on FTE.tdappleman has a great reputation on FTE.tdappleman has a great reputation on FTE.tdappleman has a great reputation on FTE.tdappleman has a great reputation on FTE.
It seems to vary slightly between years - most 7.3's take between 14-15 quarts. Start with 14 and after starting it and verifying no leaks, turn it off and let it sit for a couple of mins and check the level again. Make sure either you (or your shop) is pre-filling the filter with oil - it holds about 1/2 a quart.
__________________
2003 Excursion EB 4x4 V10, Toyo Open Counry AT2 285/75R16, Hawk LTS pads, Carquest AGM battery, Rancho RS9000XL shocks and Rancho 5410 steering stabilizer
1974 Bronco 4x4 - 302, 3spd - Restored beach toy
2013 Explorer Limited AWD
ASE Certified Technician www.coastalfastlube.com
  #6 (permalink)
Old 05-03-2011, 07:50 PM
Curt's05's Avatar
Curt's05 Curt's05 is offline
Wiser by FTE
Curt's05 has a great reputation on FTE.Curt's05 has a great reputation on FTE.Curt's05 has a great reputation on FTE.Curt's05 has a great reputation on FTE.Curt's05 has a great reputation on FTE.Curt's05 has a great reputation on FTE.
if your ok with walmart $19.00 gallon for rottella synthetic c6 15w40. They also have the ford filters, sometimes
__________________
05 eb 6.0 psd, edge insight, coolant filter, 4" ss exhaust, egr delete, studs, sct & matt's custom tunes, atlas 40 ficm tune, road master as, v code front springs, rs9000's, 2.2 k inverter, viper remote, frozen rotors/hawk pads, alpine amp/ 2 10" sub, 27 watt! led back-ups, rear view camera mirror, power-max turbo, harley headlights, hood liner,jimmi jammers, bk running boards, F650 lower dash, blue spring, true-trac, 2010 super duty mirrors...
  #7 (permalink)
Old 05-03-2011, 09:52 PM
I take it to the dealer. I called today for a price and it was $62.00. They use 10-40 oil and, of couse, uses the ford oil filter. I think it would be about even, price wise.
Thanks for the help.
BTW, one time they did it, Ford dealer in Leavenworth, KS. they didn't get the drain plug on tight and the oil drained out while my wife and two of my kids were driving it in sub-zero weather. Thank the Lord, some firefighters would driving by and stopped and gave my family a ride to the fire station.
It had been a loooong time since I was that angry and upset. They admitted their mistake, but didn't even get an apology. They pay kids $7.00 per hour to work on a 50k truck. Go figure.
Joe
  #8 (permalink)
Old 05-04-2011, 12:11 AM
EXv10's Avatar
EXv10 EXv10 is online now
EXv10 has much to be proud ofEXv10 has much to be proud ofEXv10 has much to be proud ofEXv10 has much to be proud ofEXv10 has much to be proud ofEXv10 has much to be proud ofEXv10 has much to be proud ofEXv10 has much to be proud ofEXv10 has much to be proud ofEXv10 has much to be proud of
It's always cheaper and safer to do it yourself, plus you get a little more familiar with your truck. I saw a kid drain the tranny instead of the engine by mistake one time and I didn't stick around to see where he put the oil. When 2 novices are working on it at one time it is easy to screw it up. I would never let anyone change mine.
__________________
Brent Bradley Scenic photographer and former mechanic with car and motorcycle drag racing background. Also, avid snowmobiler.......retired. The Ex; custom mudflaps
  #9 (permalink)
Old 05-04-2011, 01:46 AM
tims01's Avatar
my jiffy lube uses rottella synthetic c6 15w40. and a filter is a filter .. for $73.00 military discount
  #10 (permalink)
Old 05-04-2011, 08:17 AM
wbuffetjr1's Avatar
wbuffetjr1 wbuffetjr1 is offline
wbuffetjr1 is starting off with a positive reputation.
Quote:
Unfortunately this is very untrue!
__________________
CHAD - 2002 Excursion - 7.3L 4x4 -V/Modified F codes, Icon 3" hanger lift, Icon Dual Shock Hoops, Icon Dual Steering Stabilizers, Bilsteins, 4.10 gears, Mag-Hytecs, Detroit Locker in rear, True Trac in the front, 20" take offs, 37" Toyo MTs, 6.0 Tranny Cooler, BTS Valve Body, Hellwig, Adjustable Trac Bar, AIH Delete, HPx, FRx, Plenum Inserts, Riff Raff boots, Foil delete, Terminator T500 HPOP, Performax Gauges - Boost, Pyro and Trans.
  #11 (permalink)
Old 05-04-2011, 10:09 AM
TXSailor's Avatar
TXSailor TXSailor is offline
2011 Ford E-350 Super Duty
TXSailor has a good reputation on FTE.TXSailor has a good reputation on FTE.
I buy oil in gal jugs (Mobil Delvac 1300) at Sam's Club for $42.52 a case (includes tax). They also have Rotella and sometimes others for the Diesels.
Walmart (which is right next door to SAM's) has the Ford filters ffor the 7.3L at $9.95 each (plus tax).
I put a Fumoto valve on the drain pan and don't even get a drop of oil anywhere it shuldn't be plus I know that it's been done correctly.
I end up spending less than $55 to change the oil myself. I also pull a sample off and send to Blackstone Labs using the money I saved by doing it myself to pay for the Oil analysis ($25). Bottom line is I get the oil changed AND understand more about how the engine is "wearing" for about the same cost as the Delaer Oil change only.
Yes I do get coupons every so often from the Ford Dealership with "specials" but I like knwoing whose had their hands on one of the most ciritcal aspects of maintenance for a diesel.
D
__________________
__________________________________________________ ____________________
2011 F350 King Ranch 4WD, 6.7L,5100 Bilsteins, 7100 Bilstein SS, Hellwig Sway Bar.
FOR SALE -2002 Excursion Limited 4WD 7.3L PSD; 3.73 LS; Edge Evo 2, 285R16 Michelin LTX AT, 4" MBRP TurboBack W/5" Tip, AFE Stage 2 w/Pro 7 , HPX, 31 row AT Cooler, RAS , V-codes, Hellwig, Rancho Shocks.
  #12 (permalink)
Old 05-04-2011, 10:13 AM
TXSailor's Avatar
BTW - The Ford Oil filter holds 2 quarts of oil........ I always pre-fill it to almost full before spinning it on. Also mark the date and mileage on the filter w/ a Sharpie in case I can't read my writing in my Minatenace log............
__________________
  #13 (permalink)
Old 05-04-2011, 10:37 PM
EXv10's Avatar
I'm sure some filters that cost more are better and could make the difference between a good motor and a blown one.
__________________
  #14 (permalink)
Old 05-04-2011, 10:41 PM
EXv10's Avatar
Quote:
I change oil at every 5k miles in multiples of 5,000. (135,000 140,000 145,000 etc) Iv'e been doing it all my life and you can't miss and don't need to log anything.
__________________
  #15 (permalink)
Old 05-04-2011, 10:46 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is online now
1997 Ford F-250
White 97 xlt has much to be proud ofWhite 97 xlt has much to be proud ofWhite 97 xlt has much to be proud ofWhite 97 xlt has much to be proud ofWhite 97 xlt has much to be proud ofWhite 97 xlt has much to be proud ofWhite 97 xlt has much to be proud ofWhite 97 xlt has much to be proud ofWhite 97 xlt has much to be proud of
Boy, Have you been mislead!!!!!!!!!!!!
__________________
No matter how carefully you choose your words, they'll always end up being twisted by others!
1993 Thunderbird LX 3.8L AOD.
1997 Explorer XLT 4X2 4.0L SOHC 5R55E
1997 F-250 HD Extended cab, long bed, 5.8L, E4OD.
Tags
1979, 1997, 2011, 400, 58, 62, 67, duty, f150, f350, ford, hold, oil, quarts, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
