Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 05-03-2011, 09:42 AM
littlefoot littlefoot is offline
Garage is empty, add now
littlefoot is starting off with a positive reputation.
2004 Lightning brakes
I have a small brake problem, one of my "sliders" (the metal things that the brake pads sits on) is coming out and hitting my rim. I've put it back in place twice and bent the tab down in the back. So at this point, I'm looking about changint the rotors and pads along with replacing the slider. Is there a difference with the Lighting brakes compared to a regular f-150? AutoZone and Advanced dont ask if the truck is a lightning. But online (JCWhitney) have pads and rotors that say Lightning as an option. I want to be able to stop, but I dont need $400 worth of parts. Any Ideas?
  #2 (permalink)
Old 05-03-2011, 05:25 PM
ecoastkid ecoastkid is offline
ecoastkid is starting off with a positive reputation.
Lightning brakes are nothing special. They are essentially the exact same brakes as found on my 99 4x4 expy.
That being said, Advanced auto definately has a listing for F150 lighthing...look a little further down in the list. It will also auto populate the engine as the supercharged one since it was the only one available.
The rotors listed are 40 - 83 bucks...If your not into peformance driving, Id get the wagner stuff and call it a day. I'd avoid the "wearever" store brand. I've had nothing but probs with that on lots of vehicles.
for fronts, that puts you at about 134 a pop for the rotors. The reason they are so expensive is because its not just a rotor, its the entire hub assembly so you may want to install some new bearings (or repack your old ones if not worn) DONT over tighten that axel nut....its measured in inch pounds...barely more then hand tight.
If you look on Rockauto.com, you will get a MUCH better deal. Hell, you can get the motorcraft replacements for less then 70 bucks.
Fordparts.com even has them for 100 bucks...and you can pick them up at a dealer.
Tags
2004, brake, brakes, change, code, expensive, ford, harley, lightning, performance, problem, rotors, svt, tce, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
