Manual Injector Cleaning - The How To Thread - Page 2 - Ford Truck Enthusiasts Forums
Old 08-30-2011, 01:08 PM
HD's Avatar
HD HD is offline
HD is starting off with a positive reputation.
Thanks for description. I'm actually gearing up to change my plugs, wires, cap and rotor. I started reading about the injector cleaning and now I'm thinking I might try it since I'll already be doing maintenance in that area.
I recently did the pcv vacuum line reroute, and the engine IMMEDIATELY began running better. Since then Ive been kinda focusing my efforts moreso towards the motor running well.
So it seems you did it as a preventive maintenance type thing then. Thats cool, cause I know my 20 year old ones could definitely use it. I can keep the truck not running for a while, so I dont mind digging into something more intensive.
It doesnt throw any codes for the engine, I just get the CM code for the MLPS here and there. Dont have the number on me right now. Thank you!
Chris
Old 08-30-2011, 04:34 PM
Bankrupter Bankrupter is offline
Bankrupter is gaining momentum as a positive member of FTE.
I vote for a sticky on this one ... Rated and reped ... good stuff !
Old 08-30-2011, 05:47 PM
nstueve's Avatar
nstueve nstueve is offline
nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.
Chris
1.) no problem
2.) I did it b/c it seemed silly to put old clogged injectors back on my freshly rebuilt 351w...
Quote:
Not to diss the admins but.... It seems like the 80-86 thread has it more figured out.... I try to write up important "how to's" so they can be made a sticky but............well........ The admins seem to never be looking.
If I was a admin I would have made a "how to" sticky with links to all the pictorial "how to's" that I've seen and found; and also label each link for the info it contains. There are tons of great threads out there but no one has made a concerted effort to organize them for the the 87-96 crowd... Not to name names, but it seems like we have quite a few people with over 10K posts now and would've thought one of them could be made a admin in order to make stickeys for us... Then again I don't know the pre-requisites for being an admin...
Old 08-30-2011, 07:10 PM
Quote:
Originally Posted by nstueve View Post
1.) no problem
Well I am a VB pro/hack/admin but this site has not even seen a upgrade for a bit... 3.7.5 Mods can make sticky's btw. Don't need to be a admin. Unless the powers that be have the mods locked up to be gimps mods/super mods can do almost everything in VB. An admin could make the sections for them to put it in though ... I dont volunteer nor want to be staff here unless you pay 65 a hr.. then maybe id help out lol.
Ear Staff......... whats the deal ?
Old 08-31-2011, 01:14 AM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
Repped (Previously) and rated it just now...Definantly sticky material!
Old 09-08-2011, 11:29 PM
Blue Rebel's Avatar
Blue Rebel Blue Rebel is offline
Blue Rebel has a good reputation on FTE.Blue Rebel has a good reputation on FTE.
Quick question for ya. Does just momentarily hitting the injector w/ 9V open it and it stays open, or do you need to maintain the voltage while you blow it out?
I plan on doing this to a set of injectors this weekend, prepping for my 351 swap
Old 09-09-2011, 10:54 AM
nstueve's Avatar
Honestly I'm not 100% on this. I have always used a battery hooked to the injector wire with a interupter switch. I hook up the injector, flip the switch on and blow it out, and then turn the switch off. Thats how i do it with constant power running to it but you might be able to "signal" it open and closed... not sure...
Old 09-09-2011, 08:12 PM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
You do have to hold power to the injector to keep it open. A 9V battery should be fine. Any bigger battery with amperage could burn up the injector's coil unless you put a ballast resistor(head lamp or ignition coil ballast) in line with the injector. Most ECU's have current limiting outputs so the injector don't burn open.
Old 09-09-2011, 08:57 PM
Blue Rebel's Avatar
ok cool thanks.
Old 09-11-2011, 06:29 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
Thanks for posting this very useful thread! reps sent...
Old 09-12-2011, 08:30 AM
nstueve's Avatar
Quote:
I have a 1/2 spent motorcycle battery that I have been using and haven't had a problme yet, but the 9v fire alarm battery is the best way to go! I've burnt up a few injectors putting too much power to them! LOL... If need be a old 50cc moped battery is 6v I believe.
PS: I went back and edited Step: 3 so it is more clear to use a 9v or under power source and to keep constant power to the injector to keep it open. Thanks for the edits guys!
Old 09-12-2011, 06:43 PM
w6pea's Avatar
w6pea w6pea is offline
"Old Jarhead"
w6pea has a good reputation on FTE.w6pea has a good reputation on FTE.w6pea has a good reputation on FTE.
A great big Thank You
nstueve
I have been having problems with my engine running rough. I am going to try this myself maybe I can save a couple of bucks instead of making my mechanics weekly payroll for him
Thanks again.
Go Haweyes
  #28
Old 09-18-2011, 11:31 PM
Blue Rebel's Avatar
Here you go, Injectors all rebuilt ready to go back in the engine, and a shot of what my soaking fluid looked like after a week of sitting... This stuff started clear!!
  #29
Old 10-14-2011, 08:46 AM
83capril's Avatar
83capril 83capril is offline
83capril is starting off with a positive reputation.
Very good info here. I think I will have to make a trip to the Junkyard and buy a set to clean and install. Thanks for the writeup and taking your time to put in the good pics ect.
  #30
Old 04-10-2012, 03:30 PM
hivoltj's Avatar
hivoltj hivoltj is offline
hivoltj is gaining momentum as a positive member of FTE.
Just FYI, don't leave them soaking in B-12 Chemtool for too long. I got busy with other things and left mine soak for a week or better, it ruined them. The would not hold pressure and bled down KOEO after the cleaning.
Lift and Level question (opinions needed) phlegm 1973 - 1979 F-100 & Larger F-Series Trucks 26 03-31-2016 10:32 AM
How To: Power Steering Pump Replacement nstueve 1987 - 1996 F150 & Larger F-Series Trucks 80 02-05-2016 12:33 AM
How To: Change Rear Differential Fluid dixie_boysles 2004 - 2008 F150 15 12-03-2012 08:49 AM
Weekend suspension work (WITH PICS) nstueve 1987 - 1996 F150 & Larger F-Series Trucks 58 03-31-2012 11:42 PM
V-10 + 5 Star = vardashan Modular V10 (6.8l) 10 01-04-2012 03:42 PM
Tags
302, 9v, battery, cleaner, cleaning, ford, fuel, injection, injector, injectors, make, open, trucks, volt, vulcan
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
