460 running rough...need help
just got a 1995 f250 with a efi 460. first off, truck runs rough at idle and stumbles at take off. once running down the road it will go but lacks power and can feel it missing when shifting into o/d. got it into my shop and noticed the timing didn't seem right. on the dizzy cap #1 plug wasnt set to the 1 on the cap. it was set two spots over going counter clockwise. reset wires to 1-5 and so on because they werent even in the right order. don't remember what it was but it started 1-8.... anyway truck wouldn't even start with the factory timing order. put it back to the way it was and it started back up but still ran like crap. decided to take #1 cylinder plug out to find top dead center and couldn't get the socket on cause the manifold got in the way. looks like there bigger that whats supposed to be on the block. the manifolds have all the egr ports so i would guess there for efi. im at at loss. with the timeing order, the manifolds and the all out running condition. i know i wrote alot but will answer all questions best i can.
no its efi but seems to have a carb long block. thats why all the efi stuff dosen't line up(exhaust manifold in the way of the plug), timing order is messed up(or atleast i think). and the over all reason it runs like crap. were there any 460's that had a timing order that started 1-8...?
quick question that might clear up some of the matter. will efi valve cover fit a car head. i thought i might have read somewhere that they bolt differently. if so that clarifies i have efi heads and that the exhaust manifold might be a pos aftermarket one and be the reson for the spark plug socket issues.
FuzzFace2
73
11-06-2023 05:32 PM
Brian Ski 44
09-01-2016 06:04 PM
CyFan
10-02-2009 05:48 PM
