Should I use E7TE heads on my engine build
I have a 1983 F250 with the 460. The engine is getting tired and i am starting a builder project to replace it. I work at a mechanical shop and have access to two 460s that came out of 87-96 F250s that we have scrapped. I am using the block and low end for my engine build but i am not sure if i am going to use the E7TE heads they have. I am not using any of the EFI components, it will become a carboreted engine. I dont have any other heads to put on this build so I was curious if it would be a good idea to use the E7TE heads. I am not trying to build a monster engine or any high reving machine. It will be a mild build, (I will probably be using an Edelbrock performer intake with a 600-650 cfm carburetor) please advise if these heads will be good for my project or should i do some shopping around. Thanks
Well In my oppinion i think the E7's are one of the worst as far as power wise goes(small valves, big chamber). If it were me id use your heads with maybe a little port work, straight up timing gear, bump up the compression to 9 or 9.5:1 and use the intake you listed with a 750 CFM carb. That should give you a mild, reliable 300-350 horse all day.
Grape Nehi
01-06-2017 08:04 PM
