2006 5.4 Spark Plug Change- 100% success & procedure I used
#32
Changed on 2004 5.4
Thanks for the many threads on this topic. I purchased a 2004 F-150 with 88,000 miles on it. I ordered the Lisle LIS65600 as added insurance. I ran two tanks of Lucas injector cleaner before attempting.
I didn't have to remove any of the air system or fuel rails. I did remove the computer to get to #1 properly.
Although I followed the TSB and many recommendations, I did have #6 and #8 break. #8 looked unusually bad and didn't look like some of the carbon was even lose. The other 6 that came out all were tight and squeeked most of the way out which made for a lot of anxiety especially on #1 and #5. The electrode was worn down quite a bit on all of them.
The Lisle tool was a life saver. I needed to purchase an extended 15/16" socket to make it work but I had all the extensions from change on my former V-10.
I used the Sea-Fome because it had more lubricant than carb cleaner. The 6 that came out clean had lots of build up that had broken down.
With hindsight, I think I would have avoided #6 breaking had I done the procedure before but #8 would have broken no matter what.
The engine is running great now and I'm sure that the milage will get back to normal.
Thanks again to everyone who pioneered this!
Paul
Paul
#33
#35
I Love this post! I started my wife's 106,000 mile '06 Expy last night and let it run to operating temp. Removed COP's and cracked each plug about 1/16th to 1/8th turn. Sprayed PB Blaster in each hole. Let it soak over night. Today, using the easy back and forth technique, all eight came out in one piece. I am ecstatic to say the least. I'm thinking of putting my new, never used extraction tool on the mantle as a reminder of how lucky I am.
#36
#37
#38
Thanks for all the idears! Glad I did my homework before starting the job. The moment I attempted to break the #6 spark plug loose (that was the misfire code) I heard a crackle, it sounded like porcelin cracking, I loosened it a few more clicks then sprayed it with ford rust penetrant & inhibitor (the old stuff, they don't make it no more) I left it sit overnight. Next day I warmed up the engine, the worked it both directions, then the plug unscrewed, but the lower section stayed in. Fortunately, I already bought the Lisle 65600 extractor tool. I followed the directions and it worked well. Now for the other seven. I started on the #5 next, this time I used my 3/8 impact gun and it came right out. next #7, used the impact again but this one left the electrode behind. As for the other 5 plugs, I used the impact gun, but only giving it short bursts on the low setting Like zap..zap..zap.and zapped them all out without breaking another. Method, coincidence or just plain luck, who knows.
All in all, they are easier to access than the previous model and even if they do break, it not so bad.
#39
Sterling6.7
1997-2006 Expedition & Navigator
16
01-15-2018 10:36 PM
jbwheels
01-30-2017 08:34 PM
