howling in front end - Ford Truck Enthusiasts Forums
Old 05-02-2011, 01:00 PM
niceguy4872 niceguy4872 is offline
niceguy4872 is starting off with a positive reputation.
I have a howling or grinding in left front.I replaced hub was not it.Gets louder when left hand turn and nothing when making right hand turn.Could it be cv joint
Old 05-02-2011, 05:43 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
i would guess the other wheel bearing/ hub.
Old 05-02-2011, 09:37 PM
shorod's Avatar
shorod shorod is offline
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
Does the sound change when applying the brakes? Are you certain that it's coming from the front? Which hub/bearing assembly did you replace? Based on when it makes the noise, I would have started with replacing the right bearing since it would be under load on left hand turns.
-Rod
Old 05-02-2011, 11:59 PM
Does not make difference when applying brakes.Sound starts at about 25mph and stays there going up in speed and stops when you stop.But you get no sound from right side just left side.I have had my blazer bearings go bad and does not sound lake that.Could it be cv joint or just replace right side.Thanks
Old 05-03-2011, 06:51 AM
shorod's Avatar
Generally a worn outer CV joint would make noise when turning and a worn inner CV joint will make noise on brisk acceleration. A worn CV joint generally will not make noise just cruising down the road. As far as you're aware, has this truck ever had a damaged CV boot on the left side of the truck that was repaired rather than a remanufactured halfshaft being installed?
Without being able to hear the sound, I'd still be leaning towards wheel bearing, but if you have a local acquaintance that is pretty experienced with car repair, you may want to have them go for a ride and give their opinion.
Have you checked the front suspension for any looseness? What year is this truck/does it have independent rear suspension?
-Rod
Old 05-03-2011, 07:16 AM
MCDavis's Avatar
MCDavis MCDavis is offline
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
I think that Rod is right on the money.
A bad wheel bearing sounds much like the "howl" from an open tread design like a mud-terrain. That's what I always compare it to. Had bad wheel bearings on my '92 Expl and such was the case.
Old 05-03-2011, 07:54 AM
nothing ever replaced its my mother inlaws 120 000 2002 explorer On my way to get bearing.Thanks
Old 05-03-2011, 10:39 AM
Worked was right bearing.Thanks to all.
Old 05-03-2011, 11:05 AM
MCDavis's Avatar
Glad you got it fixed!
Old 05-03-2011, 09:14 PM
steve(ill)'s Avatar
not a sure bet, but thats the best bet when you hear howling.
Old 05-03-2011, 09:59 PM
shorod's Avatar
Glad to hear you got it fixed. It must not have been too difficult to replace. Thank you for the follow-up!
-Rod
Old 08-14-2014, 06:12 PM
TWODOGS522001 TWODOGS522001 is offline
TWODOGS522001 is starting off with a positive reputation.
My 2004 explorer makes the same noise, but mine stops when I turn left and howls more when I urn right. I replaced the hub and still doing the same thing
2004 Expy 4wd wheel bearing bad? kevb 1997-2006 Expedition & Navigator 2 01-10-2016 09:00 PM
growling noise with intermittent metal grinding noise in front end resq302 Explorer, Sport Trac, Mountaineer & Aviator 9 09-29-2015 07:41 PM
i believe its the trans that howls in 4wd high SuperDutyScaler 1999 to 2016 Super Duty 46 09-09-2015 05:08 PM
2002 Explorer wheel bearing noise?? natew Explorer, Sport Trac, Mountaineer & Aviator 2 07-12-2015 08:48 AM
04 ford explorer howling/humming front end Nkroogman08 Explorer, Sport Trac, Mountaineer & Aviator 5 05-12-2013 09:55 PM
Tags
1999, 2002, assembly, barring, bearing, cheap, explorer, ford, front, howling, hub, noise, sport, trac, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
