Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Sign in using an external account
Register Forgot Password?
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
  #1 (permalink)
Old 05-01-2011, 11:42 PM
watts127 watts127 is offline
2006 Ford F-150
watts127 is starting off with a positive reputation.
truck spudders at full throttle
I have a 06 f150 5.4 flex fuel with cold air and superchip. when I gun the throttle when truck is semi-cold it spudders. when truck has been driven for an hour or so it does just fine. I noticed this problem around the same time that I put on the K&N cold air and it seems to not matter what tune or fuel octane I use. I have thought that it may have something to due with the throttle body spacer or an air fuel mixture problem with the aftermarket intake, but I am unsure. It still does it when on the stock tune so I am certain that it is not the chip. If anyone has had this problem or may know that the problem is please respond.
  #2 (permalink)
Old 05-03-2011, 10:24 PM
C F Industries C F Industries is offline
Garage is empty, add now
C F Industries is starting off with a positive reputation.
Do you have a scanner to look at the data stream?
It might be that with the aftermarket intake plumbing, the inlet air tem sensor may not be sending the right signal to the ecm causing the wrong fuel table to be used by and causing the stumble.
Just a thought.
  #3 (permalink)
Old 12-13-2011, 05:21 AM
jbc19d's Avatar
jbc19d jbc19d is offline
2006 Ford F-150
jbc19d is starting off with a positive reputation.
My truck has been doing the same exact thing since I put my Volant Cold Air Intake on. I still haven't figured it out so if you have any luck please let me know. Thanks
  #4 (permalink)
Old 12-13-2011, 07:43 PM
Greg B Greg B is offline
Greg B is gaining momentum as a positive member of FTE.Greg B is gaining momentum as a positive member of FTE.
It has leaned out the AF mixture enough that you need new tunes written to compensate for the increase in airflow. If I were to guess, would would really notice this problem if you were towing whether cold or warmed up. That is assuming that there are no vacuum leaks and the installation is correct, of course.
  #5 (permalink)
Old 12-13-2011, 08:39 PM
jbc19d's Avatar
2006 Ford F-150
Install is correct and I've checked several times for vaccum leaks. Im pretty familiar with both but haven't had the AF mixture changed! Not real sure how to go about that.
  #6 (permalink)
Old 12-14-2011, 02:24 PM
It sounds to me like you'll need a custom tune that increases fuel flow to make the AF ratio correct again using the CAI.
  #7 (permalink)
Old 12-15-2011, 09:39 AM
Rudeman's Avatar
Rudeman Rudeman is offline
2005 Ford F-150
Rudeman is starting off with a positive reputation.
Is the fuel filter new?
__________________
Rudy Cardenas
Belleville IL
2005 F-150 4X4 XLT Supercab
5.4L Triton 3V
  #8 (permalink)
Old 01-01-2012, 11:00 AM
BF750 BF750 is offline
BF750 is starting off with a positive reputation.
check the throttle body. Had an issue after I installed K&N as the oil allows dirt to build in the TB causing accerlation, stalling issues.
Removed the filter and installed a Fram, cleaned the Tb and problem resolved.
  #9 (permalink)
Old 01-04-2012, 08:37 AM
  #10 (permalink)
Old 01-06-2012, 11:56 AM
BatteriesNotINCL's Avatar
BatteriesNotINCL BatteriesNotINCL is offline
2004 Ford F-150
BatteriesNotINCL is starting off with a positive reputation.
I had the same problem when I put a K&N on my truck...and it was only the filter... that oil slowly but surely seeps its way back into the TB and if you have a CAI then it will diminish the quality of reading of the MAF sensor... Do you hear pinging or knocking when you start up the truck until it warms up?? Like mentioned above it may be the insufficient map for the amount of Air/Fuel Mixture...temporarily bogging your engine down...
__________________
Edge Evo;Rancho Shocks;Super40;AEM CAI W/Poweraid TBS;2,000w 6.2 Audio;GPS Tracking;PIAA 4000K Bulbs;SMD Interior LEDs
  #11 (permalink)
Old 02-22-2012, 04:04 PM
2006 Ford F-150
So I cleaned my TB and still does it, so this weekend I am going to clean my MAF sensor and see if that has any luck with the spudder problem. If that doesn't work does any one else have any ideas.
  #12 (permalink)
Old 02-22-2012, 06:40 PM
critterf1's Avatar
critterf1 critterf1 is online now
critterf1 is gaining momentum as a positive member of FTE.critterf1 is gaining momentum as a positive member of FTE.
Put the stock air box back on and see if it helps.
__________________
Speed is a question of money. How fast "CAN" you go?
  #13 (permalink)
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed is starting off with a positive reputation.
How many miles on the spark plugs?
__________________
Ford senior master tech
Every 5.4 3V owner should have Lisle tool #65600
  #14 (permalink)
Old 02-22-2012, 07:12 PM
2006 Ford F-150
I don't have the stock air box any more have had the CAI for about a year and a half and got rid of the stock air box about 6 months ago.
The plugs if they have never been changed before (Idk if the plug have been changed before, I am second owner bought it with 48000 miles) have 90k miles on the truck now. But planning on have the plugs changed over spring break and coil packs too.
  #15 (permalink)
Old 02-22-2012, 08:07 PM
Time for a tune up. If new plugs and boots don't help, check the FPDM. It's located on the X-member just ahead of the spare tire. They have been know to corrode thru and cause fuel flow and pressure problems.
Tags
05, 06, 2004, 54, f150, ford, full, inline, pinging, problem, spudders, stumbles, throttle, v8, wot
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
