96 7.3 front timing cover cracked
Old 05-01-2011, 11:09 PM
faycotrophyhunter's Avatar
faycotrophyhunter
faycotrophyhunter is offline
got my 7.3 in the shop for a coolant leak. front timing cover is cracked and mechanic cant locate a timing cover. local ford dealer cant find one either. they say the part is obselete. does anyone know of a place to find one? any and all info would be greatly appreciated. thanks.
Old 05-02-2011, 02:46 AM
bad12jr's Avatar
bad12jr
bad12jr is offline
Depending on where it is you may be able to tig it. Mines cracked right by the oil cooler. I bought a used motor cheap for parts. Check local yards. Where are you located.
Old 05-02-2011, 10:31 AM
faycotrophyhunter
located between austin and houston, texas. mechanic said that he didnt want to try to weld it because of the heat may warp it then we have nothing to work with. he said he tried salvage yards and no luck either. been lookin for almost 3 weeks already. i found one for a 94-95 but its a little different from what i read.
Old 05-02-2011, 02:51 PM
Muktown's Avatar
Muktown
Muktown is offline
Call ed at www.partsguyed.com he might be able to dig one up for you. He's a site sponsor here
Old 05-02-2011, 03:13 PM
bad12jr's Avatar
bad12jr
bad12jr is offline
Yes they are different. And take a few more things to make them work. Such as the oil pickup and oil pan. They also have no anti drain back.
Old 05-02-2011, 03:20 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Parts Guy Wyatt is offline
Former Vendor
obsolete. no mas wayno.
Old 05-02-2011, 04:59 PM
bulla's Avatar
bulla
bulla is offline
I can get my hands on one. I'm in lale Charles , la for a hundred bucks or so. It's on a motor I want to buy but it's a 97 so the front cover is of no use to me. I also may be able to weld your original. Let me know if interested!
Old 05-02-2011, 05:28 PM
Action4478's Avatar
Action4478
Action4478 is offline
To OP , if it is already leaking how could it hurt to weld it. There is a product available called Alumiloy (sp) it then can be welded with a propane torch rather than a tig ..
Old 05-02-2011, 05:31 PM
bulla's Avatar
bulla
bulla is offline
Kinda what I thought.
Old 05-02-2011, 06:34 PM
fordpride's Avatar
fordpride
fordpride is offline
Originally Posted by bulla
I'm in lale Charles
bulla i didn't realize you are from Lake Charles La. i'm about 45min east of you and 30mins west of Baton Rouge
Old 05-02-2011, 06:45 PM
fordtrkboy88's Avatar
fordtrkboy88
fordtrkboy88 is offline
are you serious ? give me the info of your truck .your mechanic is bull@@@@ you check autozone type in timing cover 182.99 were i live
Old 05-02-2011, 06:51 PM
bulla's Avatar
bulla
bulla is offline
Actually in welsh so closer than that. I'm in lake Charles everyday and Jennings every other day for church!
Old 05-02-2011, 07:23 PM
fordpride's Avatar
fordpride
I drive trucks for GE and i deliver to Lafayette, Crowley, and Kaplan Monday -thursday
If you every need a xtra hand with your ride PM i'd be happy to help
Old 05-02-2011, 10:30 PM
faycotrophyhunter
will the 97 work on a 96?
Old 05-02-2011, 10:32 PM
faycotrophyhunter
1996 F250 Auto 4x4 7.3 PSD
Quick Reply: 96 7.3 front timing cover cracked
