96 7.3 front timing cover cracked - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 05-02-2011, 12:09 AM
faycotrophyhunter's Avatar
faycotrophyhunter faycotrophyhunter is offline
faycotrophyhunter is starting off with a positive reputation.
got my 7.3 in the shop for a coolant leak. front timing cover is cracked and mechanic cant locate a timing cover. local ford dealer cant find one either. they say the part is obselete. does anyone know of a place to find one? any and all info would be greatly appreciated. thanks.
Old 05-02-2011, 03:46 AM
bad12jr's Avatar
bad12jr bad12jr is offline
bad12jr is gaining momentum as a positive member of FTE.bad12jr is gaining momentum as a positive member of FTE.
Depending on where it is you may be able to tig it. Mines cracked right by the oil cooler. I bought a used motor cheap for parts. Check local yards. Where are you located.
Old 05-02-2011, 11:31 AM
located between austin and houston, texas. mechanic said that he didnt want to try to weld it because of the heat may warp it then we have nothing to work with. he said he tried salvage yards and no luck either. been lookin for almost 3 weeks already. i found one for a 94-95 but its a little different from what i read.
Old 05-02-2011, 03:51 PM
Muktown's Avatar
Muktown Muktown is offline
Muktown is gaining momentum as a positive member of FTE.Muktown is gaining momentum as a positive member of FTE.
Call ed at www.partsguyed.com he might be able to dig one up for you. He's a site sponsor here
Old 05-02-2011, 04:13 PM
bad12jr's Avatar
Yes they are different. And take a few more things to make them work. Such as the oil pickup and oil pan. They also have no anti drain back.
Old 05-02-2011, 04:20 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt Parts Guy Wyatt is offline
Former Vendor
Parts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud of
obsolete. no mas wayno.
Old 05-02-2011, 05:59 PM
bulla's Avatar
bulla bulla is offline
bulla has a very good reputation on FTE.bulla has a very good reputation on FTE.bulla has a very good reputation on FTE.
I can get my hands on one. I'm in lale Charles , la for a hundred bucks or so. It's on a motor I want to buy but it's a 97 so the front cover is of no use to me. I also may be able to weld your original. Let me know if interested!
Old 05-02-2011, 06:28 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
To OP , if it is already leaking how could it hurt to weld it. There is a product available called Alumiloy (sp) it then can be welded with a propane torch rather than a tig ..
Old 05-02-2011, 06:31 PM
bulla's Avatar
Quote:
Kinda what I thought.
Old 05-02-2011, 07:34 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Quote:
Originally Posted by bulla View Post
I'm in lale Charles
bulla i didn't realize you are from Lake Charles La. i'm about 45min east of you and 30mins west of Baton Rouge
Old 05-02-2011, 07:45 PM
fordtrkboy88 fordtrkboy88 is offline
fordtrkboy88 is starting off with a positive reputation.
are you serious ? give me the info of your truck .your mechanic is bull@@@@ you check autozone type in timing cover 182.99 were i live
Old 05-02-2011, 07:51 PM
bulla's Avatar
Quote:
Actually in welsh so closer than that. I'm in lake Charles everyday and Jennings every other day for church!
Old 05-02-2011, 08:23 PM
fordpride's Avatar
I drive trucks for GE and i deliver to Lafayette, Crowley, and Kaplan Monday -thursday
If you every need a xtra hand with your ride PM i'd be happy to help
Old 05-02-2011, 11:30 PM
will the 97 work on a 96?
Old 05-02-2011, 11:32 PM
Quote:
1996 F250 Auto 4x4 7.3 PSD
Cracked inspection cover dmamfmgm 1994.5 - 1997 7.3L Power Stroke Diesel 9 12-01-2015 08:02 PM
7.3 crack at timing chain help prgav 1999 to 2016 Super Duty 0 03-24-2015 08:00 PM
7.3 Cracked piston, where to get a replacement. cowboybootlegger Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 12-05-2011 07:18 PM
Timing Cover F350 CARP82 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 02-15-2011 04:37 PM
sending unit - '89 F350 7.3l diesel Tdiesel Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 06-26-2010 08:52 PM
Tags
1996, 250, 292, 460, 61, 73, 73l, 96, cover, crack, diesel, f250, find, ford, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
