I thought if I did not change the whole housing that I would have to use the conversion kit and I was just looking for the whole rear end but kept running into narrow frames. If I have the room to just put on the wheels that would be cool
If you have the full floating rearend you shouldn't have to change anything but the rims.
WRONG
Originally Posted by Guiny
I have a 1995 F350 SRW 4X4 CC and want to swap to a DRW axle. Can anyone tell me what years of dually axles will fit my frame and spring width
For a 95 F350 you will need a 87-97 F350 dually PICKUP axle . NOT a cab-n-chassis axle.
And you can NOT just bolt dual wheels to your SRW axle.. A DRW pickup axle is 6" wider than a SRW pickup axle and that is how you can fit 4 tires in place of 2.
I just got to thinking about the anti lock brake. It appears mine is some sort of electronic in the pinion. Did the rigs back to 1987 have something similar or interchangeable?
The VSS sensor is where you get your spedometer reading. and that is why you need a 87-97 axle. 87-91 used the sensor for ABS, but it does the same thing
