2006 F350 6.0 crazy problems - Ford Truck Enthusiasts Forums
Old 05-01-2011, 09:42 PM
bazeven2 bazeven2 is offline
bazeven2 is starting off with a positive reputation.
I'm experiencing some crazy issues, and wondering if it's maybe not my service department. Quick synopsis:
Purchased a 2006 F350 last summer with 45k miles (still under warranty)
Drove the truck from Florida to Minnesota with 0 issues
Took it to the service dept for a once over to make sure all was good
Had some minor engine items replaced under warranty (injectors, etc)
Was told that the computer was not programmed for this truck, and they reprogrammed it and flashed it to the latest update (Aug '10) Truck wouldn't start...
Was told there was an issue with the ECM and that it was the incorrect one for the truck. BUT the sticker on the side of the ECM was the correct part #. Could still not program it... They ordered a new ECM, installed it, put on the Aug '10 firmware, and the truck ran.
Didn't notice, but was told that I had the wrong gauge cluster in the truck. Interestingly, that was the only Ford warranty item done prior to me buying the truck. The fuel gauge wasn't reading correctly at 5k miles, so the dealer in Florida changed the cluster. Problem is, they put in a Gas cluster. Had the cluster replaced under warranty since it was a Ford dealer mistake.
Once the cluster was replaced, it now has an ABS light on.
Ford Service Dept reads the code and it is B2900 - VIN Mismatch.
Tech is having problems getting the proper VIN # programmed into the computer. Does the VIN need to be programmed into the ABS module?
They want to charge me not only for additional diag time, but also reprogramming time to flash it to the latest 2011 software.
Am I getting taken from the service dept? Seems that if the VIN number won't go into the computer, that it is something that should be taken care of under my engine warranty.
Does anyone know if the ABS, the computer, and the Gauge Cluster all get a VIN # inputted into them? Are there additional items that have to get a VIN # programmed into them? Why would the ABS light come up with a diag of "VIN Mismatch - B2900"?
Any thoughts besides take it to a new service dept and see what they will do?
HELP please. I have another service appt set up for Thursday, and if I'm not being treated correctly, I want to cut my losses now!
Thanks.
Old 05-02-2011, 08:05 AM
Jasonszion's Avatar
Jasonszion Jasonszion is offline
Jasonszion is starting off with a positive reputation.
Dude you need to hop on down to the 6.0 forum... You will probably find more help there
Old 05-02-2011, 08:48 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 6.0L Powerstroke Diesel forum.
Old 05-02-2011, 09:47 PM
rdunagan's Avatar
rdunagan rdunagan is offline
rdunagan is gaining momentum as a positive member of FTE.rdunagan is gaining momentum as a positive member of FTE.
just bumping. this is way over my head something for cheezit, mchan, bismic, partsman. someone help the guy this is crazy
Old 05-03-2011, 01:31 AM
High Binder's Avatar
High Binder High Binder is offline
High Binder has a very good reputation on FTE.High Binder has a very good reputation on FTE.High Binder has a very good reputation on FTE.
Bumping too. This sounds interesting but I would guess a bad service dept.
Old 05-03-2011, 02:04 AM
Shawns Fords's Avatar
Shawns Fords Shawns Fords is offline
Shawns Fords is starting off with a positive reputation.
From what I can see it looks like the information did not get retrieved properly before the updates were installed. I see this a lot more often with the dodges than the fords (I work at a Ford, dodge, Jeep Dealer) but the program needs to be downloaded before updated and parts change is performed. then the original program along with the updates is installed into the new products. Thats why its not reading the vin. I hope that helps.
Old 05-03-2011, 03:49 PM
rdunagan's Avatar
bumping again someone needs to get a tech on this to help the guy out.
Old 05-03-2011, 04:00 PM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
The wrong gauge cluster and wrong PCM programming almost makes me think somebody converted a gasser to a diesel. That or it was stripped and they didn't put the correct parts back on. Sounds like a mess.
Old 05-03-2011, 04:21 PM
45k miles and the VIN #'s match and show Diesel. Wrong gauge cluster was put in under warranty. Maybe the only one they had in stock, or the wrong one in the box? From what some others have said, it sounds like if the batteries go dead, it can take out the VIN from the ABS module. I'll report back here on Thursday, hopefully with some good news! Thanks guys!
Old 05-03-2011, 04:42 PM
rdunagan's Avatar
my batteries have both taken a crap and my abs didnt wipe out. i know the memory in the pcm goes but not the pcm its self or the abs thing
Old 05-03-2011, 05:03 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
If you bought it from a FORD dealer...it's their problem.....you bought it in good faith! They should have sold it in good faith! Tell them you want your $ back or make it right!
Imagine your state's Attorney Generals Office might like to hear from you. (They protect consumers).
Old 05-03-2011, 06:09 PM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
Quote:
Now a days all these vehicles have their computers (modules) connected to a CAN, that's a Controller Area Network so that they can share data between them. Each computer has to know what the id is of each other computer so it knows what data it is getting off the BUS.
So as Shawn said, the correct way to swap out a module is to first dump its software onto the NGS, then remove the old module, install the new module, and then reload its original software. That way none of the computers think anything has been changed.
Batteries going dead should have no effect on the each computers id or software as it is stored in the computers non-volitle memory.
Old 05-03-2011, 10:58 PM
Yup, back in the old days you had to get the Calibration code off of the vehicles door in order to get the correct parts, now instead of having already programmed components, they let the tech do the work and pay him less $$$
Old 05-04-2011, 07:05 AM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is offline
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
Have to see if we can get cheezit in here to help you out.
Old 05-04-2011, 10:45 AM
Quote:
looks like We already did
Can anyone decipher this oasis? footballguyxx 6.4L Power Stroke Diesel 6 06-26-2015 06:37 AM
Downshift bump/clunk Ford Fx4 6.7L Power Stroke Diesel 12 02-17-2015 02:25 PM
Here are the 2011 TSBs EburgHDFord 2009 - 2014 F150 22 12-05-2013 06:57 AM
206 F350 w/ 6.0 - Strange problems bazeven2 6.0L Power Stroke Diesel 1 05-02-2011 01:10 PM
New reflash for all 6.4L Jakeman68 6.4L Power Stroke Diesel 30 10-22-2008 02:41 PM
Tags
2006, 2011, 60, area, b2900, controller, diesel, engine, f350, ford, id, issues, latest, mismatch, network, problems, reflash, scanner, tool, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
