'62 292 starter issues - Ford Truck Enthusiasts Forums
Old 05-01-2011, 07:41 PM
62dump 62dump is offline
62dump is starting off with a positive reputation.
Hi guys,
Been awhile since my last posting. Used the 62 dump last summer to move a lot of earth with no real problems. Went to start it for the first time the other day and found the starter solenoid wasn't working. After removing it and cleaning all surfaces, solenoid worked. Now the starter could be heard whirring but not engaging the flywheel. Tried tapping it with a tack hammer and repeatedly hitting the key to see if something would loosen up but no luck. Removed starter and found wierd pull type bendix on the end of the armature shaft. Never saw this type before but after a thorough cleaning it loosened up. Problem now is the starter gear is fully extended and won't retract. It seems to be locked in the extention position. Is there some sort of centrifugal lock that is released once the engine starts or is this a problem I'm looking at. Any info would be appreciated. Thanks.
Scott
Old 05-01-2011, 08:12 PM
flipklos flipklos is offline
flipklos is gaining momentum as a positive member of FTE.
Not a 100% on this but I think you need a new starter drive. I belive that once they are dissasembled they are basicly screwed up. Someone may know a procedure for reseting them though.
Old 05-01-2011, 11:24 PM
Jim W.'s Avatar
Jim W. Jim W. is offline
Jim W. is starting off with a positive reputation.
In my experience, they only retract after being spun hard enough by the engine starting. Seems like I have manually retracted them, but it's been years and I can't recall. I usually bolt them on engaged and start the engine.
Jim
Old 05-02-2011, 06:50 AM
Thanks guys,
I'll try bolting it up and see if the starter retracts after the engine fires. If not, I envision the sound of something like a supercharger whine in the background. Let hope not.
Scott
Old 05-03-2011, 03:50 PM
charliemccraney charliemccraney is offline
charliemccraney is gaining momentum as a positive member of FTE.charliemccraney is gaining momentum as a positive member of FTE.
A tip from John, The Hoosier Huricane, on the Y-Block site.
"Let me guess. You were playing with the starter before you installed it and got the drive gear into the "crank" position, and now it only ratchets one way and won't retract. That restricts the room you have to work with. When I run into that, I hold the starter teeth against my spinning wire brush on the bench grinder so that it ratchets. If the brush is large enough and fast enough, the starter drive will retract and help tremendously when you install the starter."
Old 05-03-2011, 07:14 PM
Y-Blockhead's Avatar
Y-Blockhead Y-Blockhead is offline
Y-Blockhead is starting off with a positive reputation.
Agree with Charlie, or John, or?? Please make sure to use eye protection when doing this, I suggest both safety goggles and face shield.
Old 05-03-2011, 08:37 PM
Thanks for the help guys. As it turns out, I installed the starter as Jim had suggested and started the engine. I guess it retracted as normal seeing as there was no sound of a starter being spun to destruction. I'm glad someone else confirmed the wire wheel theory. I was thinking there had to be some sort of centrifugal catch in the drive seeing as there were no electrical components. Lacking any other means to spin the drive up to engine rpms I tried the wire wheel on the bench grinder. Unfortunately my anemic craftsman 1/3 hp proceeded to bog down before reaching the speed necessary to retract the drive. If nothing else, I cleaned the drum on the drive pretty good. So we're back in business. Thanks again.
Scott
Old 05-04-2011, 12:53 AM
Jim W.'s Avatar
Glad it worked out Scott! I have had this happen on more than one occasion and never any real drama.
Jim
new starter wont disengage stickman161 1997 - 2003 F150 11 04-03-2015 04:02 AM
1980 F100 turn key, won't start then everything dies. Uncle Paul 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 05-22-2014 09:33 AM
Starter/Solenoid question bigoltruck Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 03-16-2013 01:03 PM
snowblower (briggs) wouldn't start websthes General NON-Automotive Conversation 3 12-07-2010 08:09 PM
Starter problem fix, eliminate a starter solenoid hav24wheel 1987 - 1996 F150 & Larger F-Series Trucks 2 01-05-2010 10:24 AM
Tags
1964, 292, 352, 62, block, f150, ford, interchange, problem, reset, starter, starters, teeth, truack, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
