HOW TO REMOVE TURN SIGNAL ASSEMBLY HOUSING? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-01-2011, 06:48 PM
878ranger878's Avatar
878ranger878 878ranger878 is offline
878ranger878 is starting off with a positive reputation.
Hey guys on my 2001 f250 XLT how do i remove the turnsignal headlight assembly. It shows to remove the two phillips headed screws between the bumper and turnsignal. I did that and its still not budging. I can see what looks like a tab. should i just pull hard and hope that tab lets go?
Thanks
Old 05-01-2011, 07:03 PM
AJB201 AJB201 is offline
AJB201 is starting off with a positive reputation.
Had to replace the one on my 99 superduty. It has the two screws along with the tabs and there are also two plastic rods that go into a rubber gasket. The do pull hard out and push hard in. Just take your time with firm pressure and it should come out.
Old 05-02-2011, 02:41 PM
Yep that worked, thank you so much!
Old 05-02-2011, 09:29 PM
Glad it worked for you!
turnsignal lever abe 1967 - 1972 F-100 & Larger F-Series Trucks 8 10-10-2012 10:30 AM
2003 Econoline - is the flasher relay in turnsignal switch assembly? toeout 1968-2013 Full Size Vans 4 09-17-2011 06:25 PM
Texas Inspection - Turn Signal Indicators Rusty_S General Automotive Discussion 12 05-31-2010 11:29 PM
Cleaning INSIDE the Headlight / Turnsignal Light Lens Bad Company Appearance & Dress-Up 2 05-09-2010 07:12 PM
TC Locking and Unlocking w/turnsignal? custom_nirvana 1994.5 - 1997 7.3L Power Stroke Diesel 9 08-25-2008 02:25 PM
Tags
99, bronco, cover, duty, f150, f250, headlight, housing, removal, remove, removing, signal, super, superduty, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
