Mirror upgrade - Ford Truck Enthusiasts Forums
Mirror upgrade
Old 05-01-2011, 05:10 PM
Powerstroke-7.3's Avatar
Powerstroke-7.3 Powerstroke-7.3 is offline
Powerstroke-7.3 is starting off with a positive reputation.
Mirror upgrade
I have the factory electric tow mirrors on my truck right now but I would love to have the tow mirrors with the turn signals in them. Is it possible to put the newer style on without it being a wiring nightmare?
Old 05-01-2011, 07:27 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Define nightmare. Yes it's possible. There are even write ups here on how to do that. Do a search in the Super Duty section for the write ups.
Old 05-01-2011, 08:12 PM
Bitterbeard's Avatar
Bitterbeard Bitterbeard is offline
Bitterbeard is starting off with a positive reputation.
Was just looking at this myself when my wife pointed out how much nicer the 05 mirrors look.
Believe this is Jack of All trades write up?
http://www.eurekaboy.com/f250/newmirrors.htm
I plan on doing almost the same thing, just need to grab some decent priced mirrors.
Old 05-01-2011, 08:27 PM
Thank you so much!! That is exactly the kind of write up i was looking for and I plan on doing this upgrade as soon as i get some extra cash and time.
Old 05-01-2011, 08:37 PM
Just an FYI as I look for a part number or turn signal mirrors for my 2002 I'm not seeing them. I do find plenty on 2003 model trucks, while still the same generation might not be the same bolt patterns, I don't know. Maybe somebody who has done this could answer the question?
You might have to buy later model mirrors that have the signals in them but will still bolt to your truck but the wiring isn't there, so you will have to run it. I find running wires, installing relays, etc. the easiest thing to do with vehicle modifications, but that's just me.
Old 05-01-2011, 09:31 PM
Blackbeltdually Blackbeltdually is offline
Blackbeltdually is gaining momentum as a positive member of FTE.Blackbeltdually is gaining momentum as a positive member of FTE.
Just as a point of information. It is my understanding that 99-2011 mirrors are basically interchangeable. I now have a set of 10 mirrors on my 99. Took off the old ones and put on the new ones. I still have to do some wiring as I didn't have any lights on mine but now have light and heaters. The wiring will go smooth when I get to it. Again, I am told that the mirrors are interchangeable.
Old 05-01-2011, 11:09 PM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is offline
Hit it!
Ponyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud of
The turn signal option came out when the 2003 mid model year change that included the 6.0 engine. They will interchange with the older trucks physically and with some simple running of some wires, you can get the turn signals and running lights to work.
Here's the writeup: http://www.eurekaboy.com/f250/newmirrors2.htm
Old 05-02-2011, 12:21 AM
Found another write up from The Diesel Stop
TheDieselStop.Com - www.thedieselstop.com
Wouldn't say it is better but more information and opinions isn't always a bad thing.
Old 05-02-2011, 02:11 AM
bluescrew's Avatar
bluescrew bluescrew is offline
bluescrew is gaining momentum as a positive member of FTE.
its not a night mare at all. i have them installed on my truck. took 2 hours and a few beer...
Old 05-02-2011, 05:33 PM
BillyBob69's Avatar
BillyBob69 BillyBob69 is offline
BillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to all
Quote:
I'll second that. I put 05 mirrors on my E99. Lights, heat and power glass. Bolted right up.
Old 05-02-2011, 07:36 PM
Hit it!
Quote:
...and if Bill can do it, it must be a piece of cake!
Old 05-02-2011, 08:35 PM
BillyBob69's Avatar
Quote:
So whats your excuse for not wiring yours up completely? Huh? Why is that Chris? :P
Old 05-03-2011, 03:38 AM
truckeemtnfords truckeemtnfords is offline
truckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to behold
I installed the '08 mirrors on my '02 and the spot mirrors alone made it worth it. Great improvement but pricey.
Old 05-03-2011, 07:57 AM
Hit it!
Pure laziness...
Tow mirrors 79CAMOFORD 1999 to 2016 Super Duty 8 08-08-2016 04:28 PM
1995 e350 towing mirror conversion 67camaro 1968-2013 Full Size Vans 5 07-25-2016 04:21 PM
SWAP: Tow Mirrors to Signal Tow Mirrors A/Ox4 1999 to 2016 Super Duty 4 05-15-2011 09:38 PM
Another towing mirror question remix01 Excursion - King of SUVs 1 02-19-2010 02:26 PM
tow mirror from 04 fit 02? billygoat Excursion - King of SUVs 9 01-17-2007 09:10 AM
Tags
08, 1999, 2008, 350, 95, 99, f250, f350, ford, mirrior, mirror, mirrors, powered, upgrade, upgraded, upgrades, upgrading
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
