2002 F350 4WD - Hub Replace or Repair - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-01-2011, 03:16 PM
RTFMAce RTFMAce is offline
RTFMAce is starting off with a positive reputation.
Having some issues with the 4WD on this truck. 4WD works only if I manually lock the hubs which I see is discussed elsewhere in the forums. One particular post details how to replace the stock hubs with a fully manual set.
I am debating what to do about the hubs. Is is worth trying to repair the stock hubs? What is a likely solution? Vacuum line? Dirty mechanism?
I have driven all winter with the hubs manually locked and have had no issue activating 4WD when needed. Are there recommendations or a procedure to clean and maintain the OEM hubs or are manual hub replacements the way to go?
Any advise or links to related forum threads would be greatly appreciated.
Thanks in advance!
Old 05-01-2011, 07:53 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Check the vacuum lines where they connect to the hubs. That short little hose between the hub and frame tends to rot and leak.
Old 05-07-2011, 04:12 PM
I'll start there!
Thanks for the information. Should be getting new springs and shocks early this week so I'll be hunting down vacuum lines.
Front hub rattle diagnosis tennesseex Excursion - King of SUVs 6 06-30-2016 01:24 PM
front hubs dhag911 6.0L Power Stroke Diesel 14 12-12-2013 04:00 AM
auto lock hub issue KRH1326 Ranger & B-Series 1 02-11-2013 07:15 PM
Question about Warn Premium Lockout Hubs eldorado73 Excursion - King of SUVs 7 01-21-2012 09:16 PM
Hub Caps Don't Fit New Hubs biken4him 1999 to 2016 Super Duty 0 07-17-2010 12:07 AM
Tags
2002, 350, 4wd, change, duty, f350, ford, fwd, hub, hubs, lines, manual, replace, replacing, service, super, vaccuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
