flywheel questions - Ford Truck Enthusiasts Forums
flywheel questions
Old 05-01-2011, 02:45 PM
Jayme Duty Jayme Duty is offline
Jayme Duty is starting off with a positive reputation.
flywheel questions
Many of you know that i did a 5-speed swap a few months ago. My donor truck was a 91 and my driver is a 94 factory turbo. I was just told lately that the flywheel for a 94 factory turbo is balanced different than a N/A truck. It makes no sense to me but i have a vibration above 2500rpm and thought just maybe this could be the problem. Anybody know if there is a difference in flywheels?
Old 05-01-2011, 02:56 PM
Phy's Avatar
Phy Phy is offline
Phy has a good reputation on FTE.Phy has a good reputation on FTE.
The factory turbo engine has larger piston pins, which means the piston assembly weight is different than tha NA engine.
I believe that IDI engines are externally balanced by weighted harmonic dampeners and weighted flywheels. This means that flywheels & dampeners shouldn't be swapped between the 6.9 & 7.3, and would also mean that the factory turbo dampeners & flywheels are differently weighted than the NA 7.3s...
Old 05-01-2011, 03:07 PM
Will driving with this setup cause premature tranny or engine failure until i can get the right flywheel. I am really surprised this never came up with all the questions i asked during the swap.
Old 05-01-2011, 03:19 PM
Does anybody have a part number for this, everything i find is for 88-94 non turbo
Old 05-01-2011, 03:35 PM
What is the difference between F and K code trucks, both show turbo charged
Old 05-01-2011, 03:49 PM
does anybody know what the difference is between these two flywheels and if this is what i am looking for
Sachs NFW1069 - Flywheel | O'Reilly Auto Parts
Sachs NFW1067 - Flywheel | O'Reilly Auto Parts
Old 05-01-2011, 04:16 PM
IDI Diesel IDI Diesel is offline
IDI Diesel is gaining momentum as a positive member of FTE.IDI Diesel is gaining momentum as a positive member of FTE.
I cant find to much diffeance expect the secnd link fits more applications. Could be the spring rates or tooth count. Couldnt find those specs though
Old 05-01-2011, 04:32 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
K is `94 factory turbo, F is Power Stroke.
Old 05-01-2011, 06:29 PM
farmert farmert is offline
farmert has a good reputation on FTE.farmert has a good reputation on FTE.farmert has a good reputation on FTE.
Jamye You have to remember tha there were 3 different versions of the 7.3 in 94. As far as I know both the NA and turboed 7.3 IDIs take the same flywheel, but the 7.3 powerstroke flywheel is different, and won't work on the IDI. Is that where the confusion is coming from?
Old 05-01-2011, 08:40 PM
I do understand the three different motors for 94. However i am now learning the motors are balanced different for the factory turbo and the N/A so the flywheel has to be different. I know that my truck is K code but every flywheel i find says 88-94. ???????
Old 05-02-2011, 12:23 AM
axel 56 axel 56 is offline
axel 56 is starting off with a positive reputation.
I just bought a 7.3 idi and the guy I bought it from took the after market flywheel that was on it and put it on his 6.9 with no prob he did say something about haveing to use the aftermarket clutch and pressure plate as they are a different size than the ford one but myself I do not Know.Thats just wat was said .
Old 05-02-2011, 08:49 AM
NorthernDiesel's Avatar
NorthernDiesel NorthernDiesel is offline
NorthernDiesel is starting off with a positive reputation.
For reference, this is the origin of my question to Jayme Duty, since I'm doing this swap soon. This is from the Ford manual supplement for the 94 turbo modifications:
Old 05-02-2011, 09:43 AM
Phy's Avatar
Phy Phy is offline
Quote:
Nothing I had read before said anything about different flywheels for the factory turbo. I never really thought about it until your 1st. post in this thread, but it makes sense.
Now, how much difference it makes is a good question. I've read of people interchanging 6.9 & 7.3 flywheels with no problem, & I'd have to think that the difference in piston assy. weight is greater there than the difference between the 7.3 NA vs. Turbo.
The O'Reilly links are disapointing. Based on the engine code, they claim that both flywheels fit IDI's and Strokes... You might contact Sachs directly, with their part numbers. You might get better info there.
Good luck man!
Phy
Old 05-02-2011, 10:17 AM
Thanks for all the tips, i will contact ford and sachs today to see what i cant find out. is there anyother parts you guys would change out while i have the tranny out again. the clutch is almost new (10,000miles) so am not worried about it.
Old 05-02-2011, 10:22 AM
Northern, Good info, that is the first that I heard of that, but it makes sense. You learn something new every day.
I agree with Phy on the Orilley's links, if you do a search for a 96 flywheel you come up with a different number than what they say a 94 stroke takes, but they should be the same.
Factory turbo engine swap questions bashby Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 05-17-2016 07:20 PM
SMF comversion kit questions crunky944 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 03-13-2016 12:30 PM
Think i got the wrong flywheel...New to me truck. Dodge-My-Cummins 1987 - 1996 F150 & Larger F-Series Trucks 1 01-19-2015 08:53 AM
94 turbo 7.3 idi clutch problems flywheel help? Snowseeker Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 34 12-03-2013 08:47 AM
7.3 IDI flywheel differences Blue Binder Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 10-18-2012 07:47 AM
Tags
38, 42, 73, 97, change, diesel, flywheel, flywheels, ford, idi, mustang, powerstroke, truck, vibrate, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
