Fuel filter housing replacement - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 05-01-2011, 08:11 AM
red97stroker's Avatar
red97stroker red97stroker is offline
red97stroker is starting off with a positive reputation.
Inspection of the fuel valley found it flooded with fuel. Started engine and found a leaking fuel filter housing. Upon removal of the housing I found the metal had corroded through on the front left bottom side. Obtained a housing from ford . I noticed a little difference in the old and the new one. The wire harness for the housing on the old one is routed up under the housing support, seems it was put there to keep it off the engine for heat purposes? The new one it is just loose, it will lie against the valley and valve cover. Should I re-route it to match the old one???? And next where can I get the blue hoses for the the bottom of the filter housing besides ford. Its Sunday and ford is closed. I put in the housing and the lower hose got hung on the flange and cut it. I have the part number F4TZ-9324-DA . Package contains two blue hoses approx. 2" long each. Thx, Craig
Old 05-01-2011, 08:59 AM
makomark makomark is offline
makomark is gaining momentum as a positive member of FTE.
Rerouting the wires to keep them away from the cast iron is rarely a bad idea. Temps don't get too bad on the intake and the split loom is usually adequate if it is a decent grade.
There is nothing magic about the blue hoses. You can get bulk fuel line as long as it is rated "SAE 30R9". You can search this forum and find many posts that will yield recommended lengths. And get a pack of "fuel injection" styled hose clamps.
Old 05-01-2011, 10:21 AM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
1-2 foot will get you done.
I have pictures.
It sounds like you got the new style fuel bowl and you have a 94-95?
I can post some pictures of my wire routings if you want, but most of my sensors are removed from the fuel bowl, just water in fuel sensor is still there.
Old 05-01-2011, 02:44 PM
Thumbs up Thanks ...
Information on proper hose was right on the money. Went down to local Advanced and bought the fuel injection hose SAE30R9. $ 6.00 per foot. Also bought fuel linjection clamps. Hard to tell when they are tight to me. But tightened with a 7mm until I saw a slight depression in hose. And I'm pleased to report truck started right up, no leaks and the job is complete. Thx for the info, helped a lot.
Old 05-01-2011, 07:44 PM
Talyn's Avatar
Thats plenty tight on hose clamps. Most people go waaay tighter than that. Which isn't good.
Just want enough pressure so it doesn't pop over the barb on the end.
97 F250 7.3L fuel filter leaking kdwellssr 1994.5 - 1997 7.3L Power Stroke Diesel 10 02-04-2016 09:08 AM
What else should I do while I'm flushing? noober0x 1999 to 2016 Super Duty 4 10-18-2015 08:47 AM
Update: Leaky Thermostat Housing rgp Ranger & B-Series 4 09-05-2015 11:21 AM
LOWER RADIATOR HOSE BLOWING OFF!! flamebuster 6.0L Power Stroke Diesel 19 12-28-2009 01:24 AM
heater hose routing ? oldblu65 1987 - 1996 F150 & Larger F-Series Trucks 8 06-25-2009 04:05 AM
Tags
1986, 1997, 64, 73, 73l, canister, diesel, f150, filter, ford, fuel, housing, powerstroke, removal, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
