headlight switch/tail light problem?
Old 05-01-2011, 07:02 AM
fixitman1310's Avatar
fixitman1310
fixitman1310 is offline
hey guys i have a 95 f350 with 274,000 miles with a 10 ft service bed.
i have a electrical issue going on. i have dash lights, headlights
marker lights, backup lights, brake lights all burn bright until
i turn on headlights. when i turn on lights all are bright , but tail lights
are dim. when i hit the brake, i have no brake lights or tail lights
when i turn off light switch, i have brake lights and turn signals.
turn signal switch is new, both flashers are new. any ideas guys
maybe bad headlight switch. i know how to get the headlight switch
out, but have never pulled the stem out of old switch.
help please steve n.carolina
Old 05-01-2011, 08:04 AM
makomark's Avatar
makomark
makomark is offline
I think the headlamp switch is fine. concentrate on the wiring to the rear lamp sockets. Being as bulbs go out when you hit the brakes, i'd start by making sure you have good grounds on both sides and proceed from there.
Old 05-01-2011, 08:19 AM
fixitman1310
thanks alot i will check grounds
Old 05-01-2011, 07:45 PM
fixitman1310
hey guys i found my headlght switch connector melted in the center. a brown wire
was burnt badly. insulation melted. would this affect my brake lights.
thanks
Old 05-01-2011, 07:52 PM
bad12jr's Avatar
bad12jr
bad12jr is offline
Could be causing a short. Ford sales a replacement pigtail. But you could have a wire grounding causing the plug to melt.
Old 05-01-2011, 08:46 PM
fixitman1310
thanks alot
steve
jerrysrios
Electrical Systems/Wiring
87
01-21-2024 07:33 AM
fordmodified
08-02-2015 06:17 PM
wagonerkl
01-12-2014 03:26 AM
SocialDistortionFan
07-09-2013 11:25 AM
desperado_18_2000
11-18-2011 08:32 AM
Quick Reply: headlight switch/tail light problem?
