Roller cam ID Help - Ford Truck Enthusiasts Forums
Roller cam ID Help
Old 05-01-2011, 06:59 AM
barnfind 51's Avatar
barnfind 51 barnfind 51 is offline
barnfind 51 is starting off with a positive reputation.
Roller cam ID Help
I got a roller cam that I can't seem to Id. Have no backgroud on motor.
It did come apart and with the parts it had a Parker Funnel intake which Iam not planning to use . Not sure if the cam is for the Parker. Need a more HO type cam.
The numbers on the end are CD 13009Z 361005 CWC any help with my problem? Thanks George
Old 05-01-2011, 02:36 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
The numbers probably won't help you, measure the lobe lift and duration and post it up.
Old 05-02-2011, 07:36 PM
Beanscoot Beanscoot is offline
Beanscoot is gaining momentum as a positive member of FTE.Beanscoot is gaining momentum as a positive member of FTE.
Camshaft identification
Well there was a Cam Dynamics 13009 camshaft for a small block Ford. Advertised duration of 300 degrees for both Intake and Exhaust. I found mention of it here:
Hydraulic Cams for Small Block Ford | FordMustangCar.com
Unfortunately only the left half of the table on that website is visible (to me) so the rest of the data is missing.
Old 05-03-2011, 06:45 PM
Hey Beanscoot thanks for the info this will be of great help. This cam is not what I need to much go go and RPM to come in . I have a 85 302 bored 40 over roller,I plan on using a dual plane high rise with a nice stock cam or one that will come in at around idle to 1500.Any ideas on that. I want a good running motor where the little woman won't say let me out of this truck. LOL I am running a 5peed with pretty tall gears.Thanks
Old 05-03-2011, 06:51 PM
One more thing I will be running E7 heads that are ported.
Old 05-04-2011, 01:34 AM
Camshafts
The 5.0 HO cam might be a good choice.... especially if you can get a good used one for cheap. Possibly a local engine rebuilder might have one taken out during a rebuild.
Now I'm not certain that what you have indeed is that Cam Dynamics camshaft in the link, it just seems suspiciously likely. As Conanski suggested, measure the cam lift to find out more.
Old 05-04-2011, 06:36 AM
I think that is likely close to what I have considering all the rest of the motor that I got with the trade. It had a Parker funnel webb intake the heads were ported some what,not sure what the FO had in mind with the motor to do.The cam is for sure used and I would rather put together a motor that everything works together,like I have always said the cam is the last thing you get in the mix of building a motor.Thanks for ya'lls help I will more than likely get the stock profile and get something close to that.
cam help greentruck72 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2015 07:15 PM
Valve adjustment procedure needed with cam replacement? DAT2109 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 01-25-2012 09:08 PM
roller cam lifter ? 1bad67sbf Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 9 04-21-2010 10:02 PM
Comp cams retro roller kit and dizzy gear fordzilla 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 12 11-15-2006 03:24 PM
85 351W Roller cam perryphilip Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 06-06-2003 08:20 PM
Tags
13009z, 302, 351, 58, block, cam, camshaft, engine, ford, id, identifaction, identification, identify, number, roller
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
