6.0 runaway, recall needed?
Today my 2005 6.0 F350 took me for a ride almost plowing into the car ahead of me. Ran like normal on aceration but I could not get it to decelerate and had to power brake, throw it in park and shut it down.
I immedietly called my dealer on the issue, it has now happened twice. The first time was after completing a pass on the highway but I assumed it was a Edge programmer at fault but it has been removed for a year now. It is now at the dealer.
Truck has 52900 miles on it, I had the turbo checked at 1,700 miles, 2 egr coolers and misc repairs since I bought it. Last EGR repair was 3000.00 at 48300 miles.-What should I do?- I could have easily killed someone today, still shaking!
By the way, you should NEVER use the term "power braking" in the description of your failure and near accident. In court, Ford's attorneys will ask you to define power braking, if it's a drag racing term, how you know about it and how many times you've done it. Like you said, power braking involved applying the throttle and brake simultaneously, so that's what you were doing, right?
Not want you want a jury to hear.
Repeat after me. "The truck accelerated all by itself. both of my feet were on the brake and I narrowly avoided an accident."
I was using that term thinking others could understand easier. As far as crashing into anything it would be scary to think what a f350 with a lift and 35" tires could do to anything, including me. I thought the same. What was funny was I thought the police officer three cars back was going to pull me over for irratic driving.
I had no idea what he meant by power braking, but I'm going to assume he meant he was pushing on the brakes even though the truck was accelerating by itself. Perhaps we should concentrate on WHY his truck would do that, as it is not something Ford trucks are known for.
You could have an Accelerator Pedal with a bad return spring or something otherwise preventing it from returning. Get down there and make sure the pedal pops back up by itself easily. If you push on it with your hand there should be a fair bit of resistance and it should feel smooth all the way down and back up. No grabbing. It's next to impossible for the APP sensor to fail in a way that will not leave the truck defaulted to idle, so I doubt there is a problem there.
If you are sucking any sort of oil into the intake, a diesel will run by itself. That's the nature of a diesel. Check to make sure you aren't making oil (oil is way too high), or that you're not losing oil somewhere.
Have the truck scanned for codes by someone that knows how to do it and get them all. That might give you other clues.
I think in the 3 years or so I've been here, I've only seen one other person complain of a runaway, and he finally admitted he may very well have fat footed it. Foot on accelerator and brake at the same time accidentally. You might just sit in the truck and move your foot around and see where it sits on the pedals and such. You never know.
OK, a few things to check would be your injectors (prob not), your piston rings and your CCV, and the turbo oil seals.
I don't know details about the 6.0 but in industrial applications oil mist slipping past the rings from the crankcase to the combustion chamber can cause a runaway situation (blocked CCV) but this is probably unlikely in our 6.0s. A blown turbo seal leaking oil into the intake will cause a runaway as well because oil and diesel fuel are very similar so in effect your turbo is pumping oil mist into the intake and your engine revs higher because it's the same as if you simply hit the gas peddle (more fuel= higher revs). So I would seriously look into your turbo and make sure your CCV is working.
When I lifted my foot from the gas pedal it accelerated and the turbo had to of kicked in. I went into panic mode and you loss track of what's going on and what to do. ***** and stand on the brakes quick.
It happened around a few years ago but I thought it was the edge programmer which was removed on EGR cooler issues afterwards. I was on a open highway and had little more time to react then. I have a family that witnessed that one.
I had the turbo in question first time I towed with it at 1,700 miles. It sounded like it was going to self destruct. Limped the truck to the dealership at 30 mph without a trailer. Again no code so the tech couldn't figure it out, the reflashed and everything was ok until the EGR went and the cooler.
4000 miles ago they replaced the head gaskets, EGR and some other stuff again, 3600 out of the bank. I have pulled every invoice on that truck to back up all the issues.
I know it's not the floor mats since I keep them flipped over to stay clean and they are cut out there. I didn't have the cruise on and the brake lights I'm not sure. I was taking it for inspection and IM when all this happened.
Speaking of cruise it felt as though you hit "resume" when it took off.
