Where is the cylinder head temperature sensor located on a 1999 Expedition - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 04-30-2011, 08:35 PM
mreilly24 mreilly24 is offline
mreilly24 is starting off with a positive reputation.
Question Where is the cylinder head temperature sensor located on a 1999 Expedition
I need to replace the cylinder head temperature sensor on my 1999 5.4L Expedition. Where is it located and how do you change the part?
I took my vehical to brake master and they said it will cost just over $300 dollars in labor for a $20 dollar part. I would like to change this myself but first want to know exactly where it is located.
If I read right on some other forums it should be located under the head on the passenger side.
Old 04-30-2011, 09:22 PM
pdqford pdqford is online now
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
Quote:
Originally Posted by mreilly24 View Post
I need to replace the cylinder head temperature sensor on my 1999 5.4L Expedition. Where is it located and how do you change the part?.
Under the intake manifold on the driver's side.
Remove intake manifold.
Disconnect the electrical connector.
Remove the CHT sensor.
Old 04-30-2011, 10:06 PM
Thank you we found it.
Old 11-26-2014, 02:11 PM
darkbreeze darkbreeze is offline
darkbreeze is starting off with a positive reputation.
Actually, it's not at all necessary to remove the intake manifold.
Disconnect the battery. (Use memory keeper if possible to save alarm and radio presets.)
Remove the alternator.
Remove sensor with 3/4 crows foot socket and swivel adapter.
Reverse procedure.
EEC components and what they do Racerguy 1997 - 2003 F150 18 11-02-2016 06:26 AM
P128a code jct112504 2007 - 2014 Expedition & Navigator 1 03-10-2016 12:10 PM
04 Navigator Cylinder Head Temperature Sensor Location 04Navigator 1997-2006 Expedition & Navigator 3 02-13-2016 08:53 AM
Cylinder head temp sensor issie PattiCakes 1997-2006 Expedition & Navigator 3 05-11-2015 10:12 AM
Difficult to Start Engine? Replace the CHT (Cylinder Head Temp Sensor) EVERY DETAIL 3.8 & 4.2L V6 3 10-26-2014 01:11 PM
Tags
10, 1999, 2006, 2007, cost, cylinder, engine, expedition, f150, ford, head, navigator, sensor, temp, temperature
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
