Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 04-30-2011, 07:57 PM
377191 377191 is offline
Garage is empty, add now
377191 is starting off with a positive reputation.
2000 f250 front end vibration
i have a 2000 f250 4wd with 7.3l about 2k miles...... there is a vibration in front end while driving from 40 mph on up during braking the front end will bounce between 45-40 mph there is no evidence of rotor issues in brake pedel. i have changed all shocks new tires new wheels. what the problem and whats the fix?
  #2 (permalink)
Old 04-30-2011, 08:03 PM
sorry 200k miles
  #3 (permalink)
Old 05-01-2011, 06:16 AM
high ho silver's Avatar
high ho silver high ho silver is offline
high ho silver is gaining momentum as a positive member of FTE.
jack the front up and grab the tires at the top and bottom and check for any loose play. could be the front wheel/hub assy bearings going bad.
__________________
2000 F250 SD ext. cab 4 X4, 5.4L, 4.10LS
Tags
1994, 1999, 2000, 2002, duty, end, engine, f250, ford, front, frontend, gas, shake, super, vibration, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
