outside lp gas connection
would it work if I got the quick disconnect fitting for one side and the other screws into the grill?
Is this a brand new camper? If so it should be included. You shouldn't have to buy anything.
If the camper is used (or new and you're not getting the connectors) and the parts are missing then you will need one of these connected to the external burner, and it should plug into one of these (what should be under your camper).
well I finally figured everything out, bought my quick disconnect hose, bought my WEBER Q100, and I bought the parts to remove my regulator on the grill. I hooked it all up and works great.
Before:
Test fit:
Installed:
My hose connects to the propane fitting just like a throw a way bottle, but has a quick disconnect on the other end.
Before:
Test fit:
Installed:
monckywrench
Alternative Fuels, Hybrids & Mileage
01-20-2012 02:36 PM
BEAL73
02-17-2005 07:51 AM
