Clutch inspection tips?
I'm sure there is some tool or gauge you could check with.
If you had a brake checker gauge tool thing, that would work.
But the only true way to tell is to pull it off and look at the PP and flywheel to see if there is skipping or hopping on the disks, or how far the clutch material is worn and if its to the rivets yet.
