Repalcing heater core on 91 E350 diesel - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 04-30-2011, 02:27 PM
bburrito bburrito is offline
bburrito is starting off with a positive reputation.
I have a 91 E350 with the 7.3 diesel. The heater core blew and I have been trying to replace it. I've got the new one in but I am stuck now as I did not map out where everything went when I took it out. Does it matter what I hook up to the top or bottom port on the heater core? Also, there was a T fitting three way of heater hoses. One was 3/8 and the other were 5'8's. But it seems that the ports on the heater core are bigger than 5/8ths. Am I missing something here? Anybody have a picture of what goes where?
Old 05-02-2011, 06:34 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Just a few thoughts for you Senor Burrito:
The hose ID should be 5/8" which would be 3/4" OD. If your '91 is like my '97 both hoses would be the same ID/OD
The heater core is kinda "dumb" in that it doesn't really care which tube you use as an inlet or outlet---it just holds hot coolant for the blower to remove the heat and push it into the cabin. Typically the top would be the inlet, receiving the hottest coolant first, from the port nearest the thermostat housing.
IF you're reusing the factory formed hoses there might be a restriction purposely placed inside one of them, reason unknown but I'm guessing its to slow the coolant flow in order to extract more heat. IF running your own new hoses this might not be that important.
Not sure about the diesel three way hose connection so maybe you'll want to track down where the smallest of them ran?
Sorry I can't be of more help but a photo of your own current situation might be helpful to someone here.
heater core lafermedavid 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-14-2017 01:44 AM
Bypass fitting on F350 Radiator- Can I use for coolant filter/heater bypass? My plan is: Fixnstuff Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 10-19-2015 06:11 AM
1990 5.8 heater core/box garagegods 1987 - 1996 F150 & Larger F-Series Trucks 0 07-05-2015 04:25 PM
Looking for some part availabilty or part numbers for a heater hose assembly LIGOOMBA Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 26 05-18-2012 06:23 PM
Heater hose location? JHAM 1987 - 1996 F150 & Larger F-Series Trucks 1 01-13-2011 09:12 PM
Tags
2001, 350, 4x4, 91, 91e350, 94, conversion, core, diesel, e350, ford, heater, leaking, replace, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
