Heater CORE REPLACEMENT - Ford Truck Enthusiasts Forums
Old 04-30-2011, 07:49 AM
jfbecke jfbecke is offline
jfbecke is starting off with a positive reputation.
2001 F150 4X4 I have the steam trail coming out the dash vents with the sweet smell of anitfreeze. Is this the tell tell sign of a heater core failure? If so what is needed to be done to replace the core? Does the dash board have to be removed?
Old 04-30-2011, 07:56 AM
n5926g's Avatar
n5926g n5926g is offline
n5926g is starting off with a positive reputation.
Welcome to the forum! Unfortunately it does.Luckily,I personally have never had to replace one,but have seen many "in process".....
Old 04-30-2011, 08:02 AM
What is it about these Fords? I had to have one replaced in my 1998 Explorer which cost me over $900.00.
Old 04-30-2011, 08:08 AM
n5926g's Avatar
There has been some previous discussion concerning "electrolisys" in the cores themselves.Evidently they are not well grounded to the truck frame.This produces some "parasitic" voltage which actually promotes corrosion,and ultimate failure.Correction for this is to add a ground bonding strip to the frame from the core when being replaced.
Concerning the age of your truck,I would say you are "lucky" to just have this issue now.Not bashing your truck(My first F-150 was a 97),just figure it was time for yours to go.
If it makes you feel any better,Ive seen Cheby,s blow a core much earlier than one would expect as well.
Old 04-30-2011, 08:31 AM
f15097 f15097 is offline
f15097 is starting off with a positive reputation.
heater core
Are you planning on doing it yourself?
Old 04-30-2011, 08:36 AM
Yes, I am wanting to replace the core myself. Any suggestions or tips would be helpful.
Old 04-30-2011, 11:46 AM
heater core replacement
There are some terrific how to instructions on this forum. I downloaded a copy and it was like following a recipe. I would recommend using those and a manual as a very general guide. The best advise I can give you is go slow and be patient. There is a lot of discussion about the blend door being broken because it is plastic and often if not careful you can break it removing the old heater core. It might be worth getting a new one anyway because of age and you don't want to have to do it again if you can avoid it.
Old 04-30-2011, 07:59 PM
monckywrench monckywrench is offline
monckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to behold
Get a good 1/4" drive metric six point socket set, additional extensions, a universal, and a 5.5mm socket if ya don't have one. There are many hidden screws.
Patience is a virtue. Use a digital camera to take pics of what you can see directly and what you can't for reference!
Old 05-01-2011, 12:59 AM
n3up's Avatar
n3up n3up is offline
n3up is starting off with a positive reputation.
Make sure your inlet hose has the restrictor in it or you'll be doing it again soon.
I had the core done in my 97 about a year ago. The old one just crumbled.
I've done 4 heater cores in my 84 Mustang GT and 2 in my 90 T-Bird and both of those were split from excess flow. They need restrictors.
Old 05-01-2011, 01:11 AM
Lime1GT Lime1GT is offline
Lime1GT is starting off with a positive reputation.
Old 05-01-2011, 06:32 PM
iilijah iilijah is offline
iilijah is starting off with a positive reputation.
wow im loving it. i have the same problem with my 98. i can see the core was replaced before. now it is need again. i think ill install the ground wire when i change mine.
1977 F150 Heater Core Replacement with AC wisdum 1973 - 1979 F-100 & Larger F-Series Trucks 32 05-28-2016 09:11 AM
1993 Taurus heater core f100jim General Automotive Discussion 11 12-08-2014 01:16 PM
I replaced the heater core myself in my 97 and..... rambaseball45 1997 - 2003 F150 7 03-20-2014 11:49 PM
2002 Expedition Heater Core Swap changetheworld 1997-2006 Expedition & Navigator 5 01-11-2014 04:48 PM
78 F-100 Htr. bad core with dealer A/C sholloway 1987 - 1996 F150 & Larger F-Series Trucks 2 01-04-2013 07:26 AM
Tags
150, 2001, 84, 97, core, f100, f150, ford, heater, mustang, removal, replacement, replacing, truck, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
