1989 F250 460 runs great, horrible idle - Page 2 - Ford Truck Enthusiasts Forums
Old 05-05-2011, 03:00 PM
Wayne U Wayne U is offline
Wayne U is starting off with a positive reputation.
Quote:
Originally Posted by 4 flat tires View Post
try running without the spout, it should at least idle.. did you do this when you set the timing? did it idle decent then? also check the wires out for it, maybe switch one from another truck with the same motor if you can. i have no idea of what the code means, i'm just throwing stuff out there.
i pulled out the spout and it runs the same. set the timing with the spout out and it all of a suden idels perfectly. of course i got excited and took it for a drive and it had no power to accelerate but no longer missfiring at all hardly. it apears on my system pulling the spout makes no difference so there must be a bad wire some where or mabe the ignition module on the distributor? i cant find any bad wires but could it possibly be the ign module?
Old 05-05-2011, 07:11 PM
BigRedFordTruck BigRedFordTruck is offline
BigRedFordTruck is starting off with a positive reputation.
Yes. Replace it. Keep the receipt and be careful installing it. If it doesn't work, return it. It's a five minute job on that engine to swap it out. You are living the almost identical thing I went through last year. I did the wires, plugs, hoses, the whole deal. A bud on here told me to check the IAC. Mine LOOKED fine-swapped it out and she's running like a top now. It'll set you back $40.00 or $50.00 bucks, but I think it'll help. If not, return it. Hope it helps ya. These trucks are a lot of fun!
Old 05-07-2011, 12:52 PM
4 flat tires 4 flat tires is offline
4 flat tires is starting off with a positive reputation.
Quote:
the spout gives electronic timing advance to the distributor... short for spark out... thats why you didnt have power when driving with it out. the tfi module on the distributor does have a tendency to fail, but my experience is that it just shut off and wouldnt fire. and if it did was random at best... didnt cause idle issues. i'm still leaning towards vacuum leaks... there are alot of lines that are hidden in wire looms and such. a thing to check as well is the fuel vapor lines between the charcoal can, tank, and intake. there is a valve that controls flow in the engine compartment.
Old 05-12-2011, 03:53 AM
ok heres an update... finally got some money together and got a tfi for the ignition. still hard to start and idles bad but when warmed up it idles perfectly and has more power than ever. so spout was bad but next step is to replace the IAC valve and hopefully that should help with hard to start and rough idle when cold. paycheck should be in tomaro so ill let yall know how it goes.
Old 05-12-2011, 04:09 AM
fuftransport fuftransport is offline
fuftransport is starting off with a positive reputation.
there is a crank secer on that can make it attack all funny at low rpm's
Old 05-14-2011, 02:20 PM
ok the new IAC is on and the truck runs great. all you can hear is a very random faint missfire sometimes on idle but other than that it runs beautifully, thanks for everyones help on this issue but now i must go fix a new problem that happend five minutes after installing the IAC. my front seal blew out on my transmission and its running out like a faucet. this is going to be a fun weekend pulling a tranny
Old 05-19-2011, 12:40 PM
ok well all is almost well we got the trans back in after having to replace the pump bushing and seal that goes around the torque converter and the leak went away but the darn check engine light came back again!(this truck is driving me nuts) it wants me to replace the evp guess ill give it a shot when i get paid again. the running code was 31.
Failed CA Smog HC too high Steve 1987 - 1996 F150 & Larger F-Series Trucks 18 06-03-2014 05:24 PM
Super high CO, failed emissions Homeslice Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 14 10-05-2012 06:48 AM
03 F250 V10 - Failed HC (PPM) Ray620 1999 to 2016 Super Duty 23 07-21-2012 07:50 PM
5 Star Tune and CA smog check... mwsF250 Modular V10 (6.8l) 2 02-17-2012 10:54 AM
Strange HC Problem jeddi03 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 09-07-2011 10:43 PM
Tags
1989, 460, 89, f250, f350, ford, idle, idling, problem, pump, review, rich, rough, running, runs, truck, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
