Crap! new problem. Brakes
1988 E350 7.3 ide.
I seem to have lost power boost on the brakes, what should I look at first as I have never had this problem before on any of my trucks.
I'm not familiar with this system.
Yes, all new brakes recently, fluid is up, belts are good.
Started as intermittent, now no power assist.
Pull the vac hose off the brake booster. Put your finger over the end and see if the hose sucks to your finger.
There's more formal specs if you do a search. I'd check the vacuum tubes first and see if there is a leaky hose or connection somewhere before replacing the pump. Also check to see if the belt is in good shape. I'm not sure if its the same as in a truck, but on my 88 the vac pump is directly below the alternator. A short belt runs between the two.
If the vac pump tests out ok, the booster may be at fault.
I pulled the vacuum hose off the booster and not having a vacuum gauge or knowing how much vacuum it should have I put my thumb over the hose and I can feel the pump pulse, but I kind of feel that it really doesn't have a lot of suction to it.
It pulls on my thumb but not really a good strong suction that snaps to it.
Any ideas or specs on how to do a more refined test than using my thumb as a gauge would be appreciated since it's $189.00 here locally for a pump and a miserable job to change so I don't want to start throwing parts at it.
By the way, I checked some old posts on this subject and noticed that some guys had been having trouble with their cruise as well.
I did notice surging on my cruise control at the same time this problem started.
Just courious of your findings....I started having an issue on my 92 E350 yesterday. Seemed to be only when it was raining but I had a hard pedal and no stopping. I'm planning on switching over to a semi-metalic pad tomorrow (someone thought the organic pads had issues with wet/humid weather)....Let me know
Thanks,
Joel
Thanks,
Joel
Brakes
I took it up to the IH truck repair in town and had them replace the power steering pump because I'm to busy and it's a crappy job to do on this van anyway.
They checked out the vacuum pump and although for what ever reason they don't have a vacuum gauge, they are pretty certain it's the pump.
Auto parts want's $189.00 for it here but there are some on eBay for around $90.
So if the shipping isn't too high I may try that, I'm just worried about part compatibility. When I get it changed I'll post my findings.
I have ALL the services records for this van because it belonged to a fire department, seems it's had issues with brakes for awhile, and the ambulance service center just kept putting new drums, rotors, lines, and calipers over and over.
Missed the problem entirely.
BUT, I won't have to worry about brakes for a good while!
Thanks,
Joel
Thanks,
Joel
The wet or humid might be causing to belt to slip, is this a V-belt or serpentine system?
Save your money, don't change the pads yet.
