C6 shifting hard into reverse
Old 04-29-2011, 02:22 PM
Ken Blythen's Avatar
Ken Blythen
Ken Blythen is offline
Has anyone experienced a C6 engaging hard into reverse?
I just replaced my AOD last weekend with a used C6 (checked over first by a rebuilder who said it was good). I gave it new gaskets, fluid & filters, modulator etc, & adjusted the intermediate band
It drives & shifts fine; & selects all the forward gears normally, but is harsh going into reverse.
Engine mounts, driveshaft, idle speed, etc are all ok - the issue has only been since the swap.
Thanks
Old 04-29-2011, 02:40 PM
smashclash's Avatar
smashclash
smashclash is offline
I certainly will defer to the experts but here goes. Auto trans have 2 clutches, 1 for forward and one for reverse. If you're having probs with rev then its prob that and the guy who checked over your c6 was wrong.
Old 04-29-2011, 09:42 PM
84-6.9L's Avatar
84-6.9L
84-6.9L is offline
You could check the line pressure, maybe its too high. It can be adjusted by the modulator
Old 04-30-2011, 03:15 AM
Ken Blythen
Wouldn't that affect selecting the forward gears too?
Old 04-30-2011, 08:49 AM
84-6.9L's Avatar
84-6.9L
84-6.9L is offline
I'd sure think it would. The easiest thing to do would be cancel your life insurance and have someone that likes you shift it into reverse while you are under it so you can check mounts and such under load it could also be a u-joint.
Old 04-30-2011, 02:22 PM
Ken Blythen
That's the thing........reverse is the only gear with this problem.
Universals are both good.
When reverse is selected, is full pressure be applied to the clutch immediately.......or should it engage at lower pressure, then increase?
I'm wondering if it's a valve problem.
Old 04-30-2011, 02:45 PM
84-6.9L's Avatar
84-6.9L
84-6.9L is offline
Has the trans sat for a long time? I had an e4od that did the same thing for a while then i decided to stop doing it. What worked best is i put it from P to N then to R and that smoothed it out some and then one day I pulled it strait into reverse and it did bang, I'd call a local reputable trans shop and see what they have to say, if they utter the phrase rebuild go back to the phone book and find another one.
Old 04-30-2011, 03:32 PM
Ken Blythen
It had sat for a while, but I don't know exactly how long - I'm trying to find that out.
The governor was a bit sticky for the first day, but quickly freed up......I'm hoping this reverse problem will be similar
Old 04-30-2011, 04:43 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
Pour about 8 oz of B12 or seafoam into the trans and run it for a while. If it has a sticking valve, that should free it up. The B12/seafoam will eventually evaporate from the system, but the cleaning will be done by that time. You can drain the fluid out later, and replace with fresh, if you prefer.
Sticking valve is highly suspect, since the governor was acting up at first. Was likely a sticking valve there, too.
Old 05-01-2011, 05:03 AM
Ken Blythen
Ok, I'll give it a try if it's the same in a few more days.
Seafoam engine additive is available here, but I haven't found anyone selling the trans additive yet.
LubeGard is available.....is that as effective?
Thanks for everyone's help. Even with this issue, I'm pleased with the swap - haven't checked mileage yet.
Old 05-01-2011, 09:27 AM
84-6.9L's Avatar
84-6.9L
84-6.9L is offline
its called sea foam trans tune
Old 05-01-2011, 01:50 PM
Rogue_Wulff
Which is basically just seafoam's fuel system cleaner mixed with ATF.
Most auto trans "Tune up" products contain the same basic cleaning agents found in seafoam/B12, along with just enough ATF to give it a red tint.
Old 05-01-2011, 09:44 PM
84-6.9L's Avatar
84-6.9L
84-6.9L is offline
Hmm i wasn't aware i shall save that tidbit of info for referance
Ken Blythen
15
06-11-2011 05:03 AM
southcoast
06-08-2011 02:03 PM
sbrimlow
11-04-2007 03:15 PM
Quick Reply: C6 shifting hard into reverse
