How do I grease upper ball joints?
So I put in Ed's kit yesterday (all 4 balljoints, new seals, o-rings) and also did the autolock hub clean and lube, needle bearings clean and lube, and replaced my caliper slide pins (had to get another caliper bracket for the passenger side though since one of the pins was rusted solid).
Anyhow, now to my real question. The balljoints came with strait grease fittings. I read somewhere that the 90* fittings aren't good for the top because the 4x4 axle will hit it. But how the heck do I grease the strait fitting?! I can't for the life of me figure this out.
Is there a special fitting for my grease gun? or will I need to screw in 90* fittings everytime I want to grease these?
I recently ordered this, We will see if it does the job when it gets here:
Amazon.com: Lincoln Lubricating Equipment LNC-5883 Hydraulic Coupler Assembly 90 Degree Bend: Automotive
It does the job for me.
karljay
06-21-2016 12:38 PM
JohnnyAirtime
04-14-2016 05:43 PM
