e40d problem AGAIN
Old 04-29-2011, 01:30 PM
1badshovel's Avatar
1badshovel
1badshovel is offline
e40d problem AGAIN
He guys awhile back I had some shifting problems whith my 1994 ford f350 e40d it was revving high and then going into gear hard only in 1st and second I replace the tps sensor and adjusted it the problem went away then last night started doing the same dam thing is there any other sensors that would cause this to happen have no codes spedo works fine keep in mind every part Ive replace has been factory any help would be appreciated.
