1977 F-100 restoration project
#32
Busy day yesterday
Got the front windshield installed yesterday. The guys at Georgia Auto Glass showed up on time and were $75 cheaper than I could have bought it myself.
Put the rear window in myself. The rope trick works great. If you don't have one of those special window-moulding-thingy tools, use a paint can opener. That worked really well.
Stuck the hood on. It is sitting 1/2" high, not sure why. Haven't tried to figure that out yet.
Stuck the fenders on.
Then the doors
Then I put in the seats. I was pretty happy with the LMC re-upholstery kit. Spent the rest of the day trying to get the bed wood to fit. Not a lot of success there. I was worn out by 6 PM, I'd been working by myself all day. Putting an F100 hood on by yourself is no fun at all.
Put the dash metalwork and pad back in.
Stuck a couple of pieces of door molding on and called it a day.
Then the doors
#34
The back window installation was easy. I'm glad I had pro's do the front. They said it was the single widest windshield they'd ever seen. Took them 90 minutes from start to finish.
#35
My ex-son-in-law's brother does windows for a living in Cartersville. I am thinking of getting him to come over to the house and remove the front window trim. Later, when I have finished my work, I will call him back to replace the window. If you don't mind me asking...what was the price you paid?
#36
#37
on
nice build! I'm restoring the same truck....77 Short box Flareside.
would you happen to have any pics of the original parking brake connections in and around the equalizer? it would be a big help. I'm putting mine back to original condition without any offshore parts. It's taken me almost 6 years to get to this point.
#38
#39
That is what i thought also when i seen the torque converter on the motor.
#40
Finally got tired of too small alternators and bad regulators. Followed the instructions I got here and did a 3G upgrade. Popped right in and worked like a charm. Electric fans pulling 40 amps and I'm still at 13 volts charging the battery.
$26 total. Wish I had done this two alternators ago.
#41
#42
Which thread did you use for the 3g
#44
Don't look too closely at the grille, it still needs to get cleaned up and painted.
Still need to get the turn signals working, pull the steering wheel and get the horn fixed, and I hate to say it, I've got to drop the transmission pan, pull the valve body and fix the kickdown lever. It won't go into 3rd and I'm pretty sure this KD lever isn't supposed to flop around like it does.
But we are starting to get close. After I clean it up more, I'll post some shots of the interior. It isn't anything special, though.
